offroadTB.com • View topic - Before i lift...
Before i lift...
by Cesario17 » Sun Nov 17, 2013 10:19 pm
Planning very soon to finally lift my trailblazer and put on new tires. reading all these forums seems to confuse me more :pale: will I be able to make due with: MarkMC 3 in suspension lift
Wheel spacers
or will I need new shocks and struts and all that jazz? im not too crazy about smooth or stiff ride and wont do any crazy offroading, I just need my trailblazer higher with tires etc.
Help?
and if do neeed shocks etc, recommendations?
Cesario17
by Diacom » Sun Nov 17, 2013 11:05 pm
Please do more reading before you purchase anything, the answers you seek are already here.
by Cesario17 » Sun Nov 17, 2013 11:08 pm
Cesario17
by mikekey » Sun Nov 17, 2013 11:24 pm
You can do whatever you want.
by Conner299 » Sun Nov 17, 2013 11:42 pm
Longer shocks will be required for the rear. Front struts can be reused, if in good shape. Since the front struts will be taken apart, if going with Mark's, you might consider replacing the struts. While most of the questions you asked have already been answered, a lot, answers can be hard to locate sometimes... Unless your google-fu is strong.
Conner299
by djthumper » Mon Nov 18, 2013 12:16 am
by v7guy » Mon Nov 18, 2013 5:22 am
Yes you can make do with marks 3" suspension lift, but if you "won't wheel spacers" then you can't go over a tire size that will fit without a lift... so what's the point? So get the lift, get spacers, get 32s. Put it all on the old shocks and call it good.
What exactly are you confused about?
There's a fair number of threads that lists all the parts guys have purchased as well as the debates on some of the options. I'm confused that you are confused. To be honest, most of your post is confusing.
My impression of your post is something along the lines of "I don't know what to buy, but I want to lift my truck as cheaply as possible and I don't care about the ride or the capability as long as it looks cool, please tell me what to do".
So there you are.
by Conner299 » Mon Nov 18, 2013 8:15 am
Conner299
by jonbo2002 » Mon Nov 18, 2013 8:22 am
Also as stated on Marks site
Q: Will i need new struts and shocks?
A: Both kits are designed to be used with factory struts and shocks.
Replacement of front struts and upper mounts is advised if you have
high miles and will improve handling.
jonbo2002
by Conner299 » Mon Nov 18, 2013 9:07 am
Well... The only explanation I have is my rear stockers weren't true rear stockers, but looked oddly enough like stockers. Billstein sticker, and all black. With the shocks extended, and the rear on the ground, they were about half an inch too short.
Conner299
by mikekey » Mon Nov 18, 2013 10:16 am
by navigator » Mon Nov 18, 2013 11:15 am
if you are really trying to keep this low budget, you might think about buying the 2.5" lift listed in the classifieds for $100 and buying new longer rear shocks.
by HARDTRAILZ » Mon Nov 18, 2013 11:29 am
by Conner299 » Mon Nov 18, 2013 12:07 pm
Stocks springs, with the truck completely on the ground. I usually mount the uppers first, the slide the shocks up till everything lines up, and I can slide the lower bolt home. Has never failed me, from my 91 & 93 s-10's, to my '84 OLDS Delta 88.
Conner299
by Zombie Killer » Mon Mar 03, 2014 11:54 pm
i have mark mc's 2.5" and stock all around. other then 31's and plan on doing the z71 swap but that will come with new shocks. as for just the lift stock works fine so far
Zombie Killer
by bfizzle-1 » Tue Mar 04, 2014 9:28 am
:search: :work: You really gotta read all the posts... I'm a newbie too, but I spent about 5 or 6 months at least just reading up on this stuff. These guys are the epitome of pioneers for these trucks. I trust what "MOST" of them say. I'm glad I joined this site, and I'm sure you will be too, but you gotta earn your lift, and research what's right for you!!! And also, Happy Mardi Gras from Cajun Country ma nizzle...
BFizz...
bfizzle-1
by mikepeters1983 » Tue Mar 04, 2014 10:10 am
In my experience longer shocks are not required for the rear, but are highly suggested. I am now on my third TB/envoy. The first one that I lifted i kept my factory shocks. It was a ruff ride. On certain bumps where the axle wold drop, it would sort of slam the truck down with it. On my second one, i installed longer shocks and it rode like factory. like a dream for being lifted that high with retreads, and steel wheels, and a crap ton of weight. just my thoughts
mikepeters1983
Vehicle: GMC Envoy XUV
DriveTrain: 2WD w/ G80
by HARDTRAILZ » Tue Mar 04, 2014 10:15 am
by mikepeters1983 » Tue Mar 04, 2014 10:41 am
mikepeters1983
