offroadTB.com • View topic - G80 Swap 4.2L I6
G80 Swap 4.2L I6
by crate2002 » Thu Nov 14, 2013 10:05 am
Since I am new to this, I have discovered my TB in fact does NOT have the G80. Thats depressing to figure out when wanting to complete a build. So now I am wanting to do a swap. If I am correct, I have an 8" rear. It has GU6 in the glove box (3.42). What would be my best way to go about this? Whole rear swap or internals swap? I'll have to locate one that is GU6. OR would you recomend changing the gearing front and back to 4.10? Decisions... Decisions... :wallbash:
crate2002
by Cable810 » Thu Nov 14, 2013 10:30 am
Well it all depends on your mission. The 8.6" axle is much stronger than our factory 8" axle. 4.10s are better for bigger tires but are harder to find, 3.42s are not best for bigger tires but are much easier to find. I'd also suggest to do some reading on the G80 as its not the strongest locker. I'd swap a whole new axle assembly vs having to re-gear your current axle.
by The Roadie » Thu Nov 14, 2013 10:56 am
Many of us swap in 8.6" rear junkyard axles with G80s in them for a few hundred bucks. If your mission involves trails that may put the G80 at risk, there are aftermarket lockers available for the the 8.6 and the 9.5 SS rear axle. None except the Eaton G80 available for the 8.0
by TBYODA » Thu Nov 14, 2013 11:02 am
by crate2002 » Thu Nov 14, 2013 11:05 am
So if I am understanding correctly, 8" should be swapped out with something bigger. OEM locker for trail is not that strong but an after market locker for an 8.6" swap would be more reliable?
crate2002
by crate2002 » Thu Nov 14, 2013 11:12 am
crate2002
by navigator » Thu Nov 14, 2013 11:27 am
I run 32's with 3.42s and it is fine most of the time.
Towing my bass boat in the summer in OD the tranny warms up more than I like, I've seen it as high as 228. Dropping back down to 3rd helps the tranny temps.
I live in the flat lands of NC though.
I likely would have been satisfied with 3.42s permanently with a tranny cooler installed.
I chose not to run 33's with 3.42s for fear of overheating the tranny.
I ran across a deal though and have a set of 4.10 axles waiting for me to install.
by TBYODA » Thu Nov 14, 2013 11:41 am
by HARDTRAILZ » Thu Nov 14, 2013 12:05 pm
Truetrac is limited slip, not a locker. Something I would only really consider for a front diff, but they are not offered to us for ours.
There are several discussions I would think you should read on this site and others regarding open/LS/Lockers, plus gearing. We have a limited number of options and several opinions as to what is best. Help us help you....
What tire size are you looking to run?
Mostly on-road or off-road?
How difficult of off-road? Trails or rock gardens or some dirt roads or sand?
Pull trailers?
Spend alot of time on the insterstate?
by TBYODA » Thu Nov 14, 2013 12:38 pm
by crate2002 » Thu Nov 14, 2013 3:07 pm
crate2002
by HARDTRAILZ » Thu Nov 14, 2013 3:16 pm
The trans overheating is sort of an issue. Some people blow it out of proportion, but an aftermarket cooler is cheap and easy to install. One of those things better to have and not need, than to need and not have.
I went years with 3.73 in heavy 33s and shit for aerodynamics without only getting the trans hot once in the mountains. 99% of the time it was fine and it was easy enought to baby it and keep temps ok once I saw them rising.
I did add a Hayden cooler before I jumped up to 4.10s and 35s. Since the cooler the mountains and everything else has been a non issue.
Are you wanting bigger tires or just the increased traction of a locker? If you are not going bigger and are happy with current performance...just find a cheap g80 3.42 rearend. Complete will be better in either 8.0 or 8.6 . Go to 8.6 if price close, but for your use...an 8.0 ought to be fine. Mine was for way harder abuse than you are doing.
by navigator » Thu Nov 14, 2013 3:22 pm
if you have an android bluetooth phone/tablet you can download an app called torque pro and get a bluetooth OBDII adapter (like ELM327 from ebay) and set it up to read tranny temps and lots of other items. There are a lot of folks on here that run them.
If you are like me and don't have an android phone, you can get a scangauge II to read the temps.
As Kyle mentioned it is good insurance to just get the cooler.
by crate2002 » Thu Nov 14, 2013 3:44 pm
crate2002
by crate2002 » Thu Nov 14, 2013 3:51 pm
crate2002
by mikekey » Thu Nov 14, 2013 3:59 pm
That's similar in size to what I originally had before my 35's. However I had 3.75's. I don't see why a 3.75 G80 8.6 wouldn't be just ok for 32's. Quite a few folks running just that in stock trim. I've been rolling around with 3.75 on 35's for awhile. Not recommended. I'll be going up to 4.53's after Christmas.
by HARDTRAILZ » Thu Nov 14, 2013 4:20 pm
3.73, 3.73, 3.73, 4.56
I think those are the gears he meant to type or he has some custom shit going on.
by mikekey » Thu Nov 14, 2013 7:23 pm
Yup. That's what I get for multitasking
by AlekG » Sat Nov 16, 2013 6:15 pm
AlekG
