The part # is 200-126-1
The intake came with their "Syntha Flow" air filter.
Right of, I give them credit for excellent packaging. There was a ton of bubble wrap, and the box its self has lots of info.
The kit layed out before install. Make sure to understand the parts you are dealing with. READ THE INSTRUCTIONS THOROUGHLY!! It will save you time in the end.
Bare engine bay.
Intake tube installed. Very simple. make sure to line up the tube with the groves on the inside of the silicone hose to ensure a good seal, and allow the system to move a bit with vibrations from the block.
Re install stock sensor.
Install heat shield. I used a bit of hose insulation on the bottoms of the metal to ensure a snug fit, and to keep out hot air, and un wanted air impurities.
Kit fully installed. Took maybe 20 minutes.
According to the HP book that came with my kit, for our specific model there is a 10hp gain.
I have a tuned PCM, for 89 octane, and the extra adjustments for the new intake. Right away the butt dyno says there is way more pull, the throttle sensitivity is AMAZING! I used to think my truck was this big slow bastard at times. But it is quite a bit better now.
Im gona keep a close eye on my fuel millage during my cross country drive back home.
