offroadTB.com • View topic - Front End Rebuild
Front End Rebuild
by Aries » Sun Nov 03, 2013 12:53 am
When I do my RadFlo install I'm going to take the time and rebuild as much of the front end as possible. After ten years of no front end maintinace I think this would be a wise move.
I found this list on v7guy's build thread. What's your opinion on what's necessary before I get a front end alinement.
CHEVROLET TRAILBLAZER 4.2L L6
Part Number Part Type Quantity
MOOG K200270 Control Arm Bushing - 1
MOOG K6664 Ball Joint - 2
MOOG K200271 Control Arm Bushing - 1
MOOG K200269 Control Arm Bushing - 2
MOOG K6663 Ball Joint -2
MOOG K200272 Control Arm Bushing - 2
2007 CHEVROLET SILVERADO 2500 HD 6.0L V8
MOOG ES3609 Tie Rod End $ 48.79 $ 0.00 2 $ 97.58
MOOG ES3488 Tie Rod End $ 32.79 $ 0.00 2 $ 65.58
Purchased
Aries
by Regulator1175 » Sun Nov 03, 2013 1:32 am
by v7guy » Sun Nov 03, 2013 2:42 am
Matt is correct, the bushings are a huge pain in the ass, you can save some money going with them, but generally speaking I have doubts it's really worth it unless you just want to do it that way.
As far as front end work that's pretty much everything.
by Spot u 3 » Sun Nov 03, 2013 4:07 am
Or you can just get the control arm brackets for $50 bucks a piece at summit racing. I would suggest to do the inner tie rods. There easy to do and that way your front end will be nice and tight.........just my 2 cents
Spot u 3
by ErikSS » Sun Nov 03, 2013 10:48 am
by Aries » Sun Nov 03, 2013 11:14 am
Aries
by Regulator1175 » Sun Nov 03, 2013 1:21 pm
by v7guy » Mon Nov 04, 2013 5:53 am
It should be noted that with the mevotech arms, when I helped install them on another gmt, there needed a fairly significant amount ground off the bracket to even get the bolt to go through. It also may be of interest to know that on Moots truck the balljoints lasted less than 9 months... the bushings are still ok though.
There are some benefits to swapping the individual parts. But as mentioned it's a tremendous amount of work.
You'll notice (if you look close) the price is specified as the price for 2, it's not as broke down as in the rest of the post, but it's there. It's also important to mention that those are for the HD rod end conversion, not for the stock pieces.
