Gordinho80 wrote:I've had my resonator off for years... don't even have a tip in place. I cut the resonator right after the last hanger and its never had a tip. I've had no issues with NJ inspection at all.
Same here in NC.
djthumper wrote:We have emissions checks here and I have never failed with mine just cut off
djthumper wrote: We have emissions checks here
NC_IslandRunner wrote: We have emissions test
Exactly, because in the early years of emission testing, sleazybirds would reset the codes on the way into the test location and get away with it. Now the same sort of crooks can only get away with selling used cars to rubes who don't take the time to get the codes read, only to discover horrible problems the day after they get the vehicle home.navigator wrote:From what I understand when you clear the codes or disconnect the battery it puts the systems in "not ready" for a certain number of hot/cold cycles.
Ralogsdon13 wrote: i've never been car smart by any means
I laughed and just walked away. Good thing all he does is clean cars and not actually work on them.JorDaneeKey wrote:djthumper wrote: We have emissions checks hereNC_IslandRunner wrote: We have emissions test
What is this emissions test you speak of?
james02 wrote:As per the NYS DMV....It will fail if there isn't one...Obviously the site wont let me copy and paste the verbage... Moots and V7 don't have one, sooooo...Monkey see , monkey will....And most probably fail....
Cody_S wrote:james02 wrote:As per the NYS DMV....It will fail if there isn't one...Obviously the site wont let me copy and paste the verbage... Moots and V7 don't have one, sooooo...Monkey see , monkey will....And most probably fail....
You sure this was for the resonator and not for the muffler?
v7guy wrote: technically speaking, James is correct, the law reads any modification to the exhaust system that may increase sound is illegal. The resonator delete may be able to be construed to be increasing the sound. The law also specifies that it can't be louder than the factory exhaust, since no manufacturer I know of publishes that data you can simply state it is no louder than factory and then, therefore, legal. It's on them to prove it's not legal. I don't know of anyone that has had trouble passing inspection with a modified exhaust around here, I also don't know of anyone getting tickets for it. Unless it's really really exceptionally loud and you're really really obnoxious with it, you should have no issue. This isn't any legal advice of course, but you can read your local laws and figure it out pretty easily with some time and a search on Google.
