JamesDowning wrote:I'd be surprised if that was the root cause Donny... 87 combusts more readily than 91.
Octane requirements are really only dictated by an engine's compression ratio.
Octane slows the burns cycle, it doesn't inhibit it. It's used to prevent the flame front of an ignited charge slamming into the face of the piston before the piston has reached TDC. AKA knock.
Reference the multitude of 10:1+ compression ratio engines out there today that run on 87.
I'm not sure what PCM4LESS would even change for our engine if tuning for 91. Doesn't really compute to me.
More aggressive timing curves, including more timing at idle. We added tons of timing at idle when we tuned the LT1 in my Camaro. Why? Throttle response.
My miss never produced a fuel smell or rich O2 code. I believe it's within the realm of possibility that in my case, it was a timing issue.
