by tbangert » Sat Mar 23, 2013 7:40 pm
Permanently removed the gears from my splined disconnect and replaced them with an awd spool. Next... find a way to go and pick up an 8.6 axle and get these gears off my couch and in my truck!
tbangert
by Opeth » Sat Mar 23, 2013 8:01 pm
mikekey wrote:Tires mounted to rims. Is it tomorrow yet? :cheers:
What did you balance them with... Weights or beads?
by Blazintrails03 » Sat Mar 23, 2013 8:54 pm
Finally got around to removing my intake resonator and cleaned the throttle body while I was at it. Hacked off the exhaust resonator too and hit every nut and bolt I could think of with penetrating oil to help with my lift install. Should be doing that next weekend
Last edited by Blazintrails03 on Sun Mar 24, 2013 7:46 am, edited 1 time in total.
Blazintrails03
by navigator » Sat Mar 23, 2013 9:34 pm
configured my new ScanGaugeII and added the code for the tranny temp.
by Moots1288 » Sat Mar 23, 2013 10:26 pm
Replaced rear rotors and pads, replaced wheel hubs, exhaust manifold to extension doughnut seal and exhaust manifold gasket
by chevycrew » Sun Mar 24, 2013 6:01 am
navigator wrote:configured my new ScanGaugeII and added the code for the tranny temp.
That's something I need to do!
Mine is in, just not configured for anything other than the basics.
Got a quick how to for someone that is limited on time before moab?
by The Roadie » Sun Mar 24, 2013 11:11 am
Continuing the bumper work before my brother leaves to return to the land of snow and slush and brats on Tuesday
The apprentice (me) is qualified to run the plasma cutter and do tacks and grind welds and put away the tools at the end of the day. I can't be trusted to do the finish welding yet.
by Wahugg » Sun Mar 24, 2013 1:47 pm
Looking good Bill! Where did you source the welder from if you don't weld a lot?
-Wahugg
Wahugg
by Cable810 » Sun Mar 24, 2013 2:49 pm
Wow that looks good Bill!!
by Blazintrails03 » Sun Mar 24, 2013 4:07 pm
Got my coil overs built today. Always great when its all new parts and they go together with ease. Well the lift was used but eh
Blazintrails03
by JCrayton99 » Sun Mar 24, 2013 5:11 pm
Put my exhaust back to stock minus the resonator. Oil, air filter and fuel filter. Cleaned out the clutter in the back and mocked up where my sliders are going to go.
JCrayton99
Rank: Offroad Guide
by chevycrew » Sun Mar 24, 2013 6:09 pm
Starting packing the TB for a week in Moab! Going Ultimate Adventure style, no plan, just pack for a week and go!
by JorDaneeKey » Sun Mar 24, 2013 7:16 pm
chevycrew wrote:Starting packing the TB for a week in Moab! Going Ultimate Adventure style, no plan, just pack for a week and go!
I am SO jealous........
JorDaneeKey
by navigator » Mon Mar 25, 2013 8:38 am
Hi Steve, I just saw this. I responded to your PM but will post here for others.
I got my info from this thread
viewtopic.php?f=26&t=544&hilit=Xgauge
and here
http://www.scangauge.com/support/x-gauge/gm-specific/
by v7guy » Mon Mar 25, 2013 9:48 am
Looks nice Bill, makes me want to get to work on mine. Looking forward to the finished project. The only thing that helps welding is to get time behind the torch!
Blazintrails03 wrote:Got my coil overs built today. Always great when its all new parts and they go together with ease. Well the lift was used but eh
Bobby, did you get the Icons?
That's how I saw a lot of the U.S., used to toss some clothes in the Firebird and just go for a couple days. It'd be nice to go exploring trails in that mindset.
by The Roadie » Mon Mar 25, 2013 11:25 am
Wahugg wrote:Looking good Bill! Where did you source the welder from if you don't weld a lot?
I borrowed a Harbor Freight plasma cutter and cheap flux wire welder (no gas) from Teebes/Greg. I haven't used the welder because my brother (the professional) said it didn't have the power for 3/16" plate. I wanted to use 1/8", but I gave my brother the money to go get the steel and he got his way because he felt strongly I'd be backing into rocks and he didn't want *his* bumper to get dented. I wish he hadn't made that decision for me, but he's doing 90% of the work, so I just shut up. I'll take it off and weigh it later and then cry.
The plasma cutter rocks. Never an issue except for the 30A extension cord Greg made up had a loose ground and I tightened it all up.
So the welding we've been doing with a Millermatic 175 I rented for $75 a week from the son of a co-worker who used to be in business with his Dad (muffler and brake and general repair) shop. It's a $1000-1200 unit to buy. The Dad just retired, gave all the tools to his kid, who is working in another garage now that doesn't have the 220 receptacle installed yet for the welder. Consumables are an issue, but I have to assume regular rental places who rent welders don't provide the consumables. So I told the renter that I'd give him the left over from a 10 pound spool of wire in trade for using up some of his gas. But now the gas tank is about empty and I have to trade it today and have no idea what that's going to cost. 100 CF tank of 75% argon / 25% CO2. Anybody have a guess? How do typical rental places deal with this?
Almost done now:
by Cable810 » Mon Mar 25, 2013 11:44 am
That looks nice!!
by Moots1288 » Mon Mar 25, 2013 1:05 pm
Installed scan gauge to monitor trans temp
by Karo » Mon Mar 25, 2013 3:01 pm
Wow Bill that looks really good! Some kind like stealth technology 8-)
Karo
by Blazintrails03 » Mon Mar 25, 2013 3:35 pm
Oh haha no. Just the regular Bilsteins, replacement springs (factory rate), and one of marks original kits I got from someone on here or TV I can't remember. I don't have the money or needs for the adjustables or higher spring rates.
Blazintrails03
