offroadTB.com • View topic - Shock Tube Rubbing
Shock Tube Rubbing
by Wahugg » Fri Nov 02, 2012 9:52 pm
Hey all!
I was out changing my brake fluid when I noticed this.
It appears that something is rubbing the inner side of the shock tube. What ever it is has worn off the paint and is beginning to make score marks. I couldn't see anything in the vicinity that would rub up against this area, even when under compression.
Has anyone had his problem before? Or can someone check to see if this is normal? The fact that what ever is rubbing against the tube is causing score marks is concerning me.
My rear set up is stock length Blistening HD's with Z71 springs.
Thanks for any input!
-Wahugg
Wahugg
by drwfaulk » Fri Nov 02, 2012 11:10 pm
It could be the shock sleeve rubbing when it compresses . It looks like the scores are vertical . Try to see if when the shock is compressed if it bends back in the middle to cause the rub.
drwfaulk
by 06MidnightBlue » Sat Nov 03, 2012 12:59 am
Confirmed. It is the shock "sleeve" as I like to call it. Seen it a million times at work. Also had it happen many-a-times on my TB
06MidnightBlue
by v7guy » Sat Nov 03, 2012 1:49 am
How is the shock condom rubbing on the tube in just that one specific spot?
It's not bumping something while the axle is hanging is it?
by drwfaulk » Sat Nov 03, 2012 6:55 am
drwfaulk
by The Roadie » Sat Nov 03, 2012 11:32 am
The problem is where I put the arrow. Apply some teflon tape to the area, and tuck it up under the sleeve so it doesn't catch during compression. If this bothers you too much, you might want to readjust your threshold of carnage-annoyance. :poke:
by 06MidnightBlue » Sat Nov 03, 2012 3:04 pm
06MidnightBlue
by Wahugg » Sat Nov 03, 2012 3:27 pm
Wahugg
by v7guy » Sun Nov 04, 2012 4:22 am
Crazy, nifty to see though.
by The Roadie » Sun Nov 04, 2012 11:03 am
by Lauron » Sun Nov 04, 2012 11:07 am
Wahugg,
the rubbing may just be a boot misalignment but it could be the result of mounting the shocks too rigid in the mounts. If the shocks can't rotate with compression, they will be put in bending which could cause this contact. Did you mount the Bilstein's with extra washers to take up the space of the undersized ends? I am not sure which shocks you have.
See the discussion on Bilstein rear shocks.
Build:
Lauron
