Fuel mileage.
by navigator » Fri Jul 06, 2012 10:00 am
Caleb I expect you need to clean your TB, replace your TStat and front O2 sensor.
Also the larger tires will throw your odometer off so you will have to account for that as well.
by BigBen » Fri Jul 06, 2012 10:54 am
JamesDowning wrote:If you don't mind me asking, what kind of mpg were you getting with duallys? 0.25 is significant over long drives if you're getting 5mpg.
Sorry JD I never answered your q. It's a little hard to tell exactly but with the singles I was doing 5-5.5 but I had a low pro grain trailer and my truck had a wing on top. I took the wing off and switched back to duals. With both changes I gained .5mpg. That's nearly $200 a week in fuel savings. But I did lose the 1/4 ton commodity hauling ability. Since then I switched to a normal trailer and put the wing back on. 5-5.25mpg now.
BigBen
by Cable810 » Fri Jul 06, 2012 7:51 pm
navigator wrote:Caleb I expect you need to clean your TB, replace your TStat and front O2 sensor.
I shall get to that... if I ever get around to it...... Thanks for letting me know.
The 11 was hand caculated. I drove it close to 100 miles tuesday and my DIC Mpg showed 19.4 so yea.
by Trail X » Mon Jul 09, 2012 8:35 am
There isn't normally THAT much of a difference between the DIC and the correct number. Are you sure you did your math right?
by Cable810 » Mon Jul 09, 2012 9:23 am
100% You take your Mileage and divide it by the gallons you put in or vice versa. Drove 64 miles and put in 5 some gallons. I left the receit at our cottage.... This was before the 100miles
by navigator » Mon Jul 09, 2012 9:32 am
Caleb, did you fill it up completely?
by Cable810 » Mon Jul 09, 2012 10:19 am
No. Just filled up from 3/4. Parents don't want me to go past 1/2 on the fuel info due to it not working and running out of gas quite a few times.
Sorry for the confusion.
by Trail X » Mon Jul 09, 2012 10:26 am
navigator wrote:Caleb, did you fill it up completely?
Might not have been filled up entirely the previous time...
If he didn't fill it up entirely this time, it would actually be much better than actual.
The system requires that you let it click off automatically each time.
by navigator » Thu Jul 12, 2012 8:33 am
I changed my Tstat on Sat and went on an interstate trip yesterday.
my mpg went up from ~18 to 20.5.
this is mostly 70mph on the interstate about 160 miles one way. It is the same trip I checked it on earlier.
It will be interesting to see how much impact it has on local trips.
by Jimz02TB » Tue Aug 28, 2012 1:09 pm
On mine i got 3.42 gears, 28" tires, 18-20 mpg on highway depending on how i drive, i usually run bout 75mph on highway
Jimz02TB
by 94 eg » Tue Aug 28, 2012 4:19 pm
Mine went from 13.2 on the DIC with 3.42 and 33" tires to 14.4 on the DIC once I put the E-Fans on. Ready see what what it goes to when I put the 4.10's in. This is mostly in town driving.
94 eg
by 94 eg » Sat Sep 01, 2012 4:34 pm
Well last night I put in my 8.6" 4.10 rear and all I can say about my fuel mileage is Wow! I went on a 130 mile trip this morning, when I was leaving the house I reset my average fuel monitor on my DIC and when I pulled back in the drive this afternoon in was at 19.5! This was with the cruise set at 65mph. I know this will go down once I start driving in town but I think it's going to get better mileage than I orignally thought. Remeber I'm on 33" tires and the TB was really strugging with these tires and the factory 3.42 gearing. Hopefully my 4.10 front will show up next week, then I can hit some trails.
94 eg
by JCrayton99 » Sat Sep 01, 2012 6:22 pm
This is something I was quite interested in. Im pulling 14.1 with my 33s and 3.73s.
JCrayton99
Rank: Offroad Guide
by 4angels » Thu Sep 06, 2012 12:45 am
32's 3.73's 3 inch lift, 18.6 running at 70mph.
4angels
by 94 eg » Tue Oct 23, 2012 8:15 pm
Now that I have had the rear swapped for almost 2 month my mpg's on my DIC has settled around 17.5
94 eg
by Nakashige » Sat Oct 27, 2012 11:56 am
running 19 to 21 with 34s on the Duramax
Nakashige
Vendor
by Opeth » Sat Oct 27, 2012 5:48 pm
3200lb boat, 3.42 265/70-17 12.7 mpg without calculating the difference for tire size change. 178 miles. I'm changing careers shortly and will have time to send the PCM in for a recalibration finally.
I've been waiting for a cool day to make this tow easier on the tranny but with sandy coming, and my boat insurance company telling me to review my coverage before the storm it had to happen today. Was in the low 50's, was hoping for a 40 degree day but temps seemed to stay around normal. Gotta add a cooler with bigger tires now.
by 03envoy » Fri Jan 04, 2013 5:16 pm
2.5in lift, 28" tires, 3.42 gears, 12 city, 18 highway. 500 mile trip driving 75-80
16 highway with 350lbs give or take. 2 generators and other gear.. same speed
16 highway with lighter gear and driving 85-90
03envoy
by fishsticks » Sat Jan 05, 2013 2:26 am
I just did a run to Seattle and back today, about 350 miles.
After gassing back up and doing the math, right at 15mpg, even with a little in-town driving! :excited:
by TheVoy » Thu Jan 31, 2013 3:55 pm
STOCK: 28in Tires, 3.73 gears = 15-16 City, 21-23 Highway 65mph-75mph, 19 mpg average
NOW: 32.5in Tires, 3inch Front Lift, 2.5inch rear lift, 1.5 inch wheel spacers, 3.73 Gears = 10-12 City, 14-16 Highway 60mph-70mph, 13 mpg average
02 Envoy SLT 4x4
3 Inch Front Lift - 2.5 Inch Rear Lift
1.5 Inch Wheel Spacers
265/70/17 (32.5in) Definity Dakota A/Ts
Eaton G80 Locker
TheVoy
