by Lauron » Fri Sep 21, 2012 12:26 am
I am using stock springs all around. The spacer gives you the lift without have to go to the stiffer springs for added height. I have 2" of up travel on the front before I run into the topping out of the shock. This initial install of the spacer on the old shocks was a challenge and as you can read many had problems with the spacers ballooning. My conclusion is you have to make sure the shock stud is fully made up. We used a shop wall mount compressor. The strut length picture shows the lifted strut is a little longer because the shock end is inside the spacer. The spring is much more compressed.
With the 3" body lift, I did not have to cut the body panel to flip the UCA. But it leaves a big gap open to the engine. So I filled the gap with a plastic liner bolted in with the wheel well liner. You can see how big the gap is on the fender cut out pics.
On the front, the plastic bumper is a cut clean. On the back of the front fender, I trimmed and folded over leaving a 3/4" lip. Both started about 2" at the bottom.
At the rear, under compression, the tires will likely rub front inside. I haven't yet figures out how I will make some more room there.
I will be doing some more cutting on the front and the rear this weekend so these will come later.later.
- Attachments
- Lift gap fill old pic.JPG (30.9 KiB) Viewed 27151 times
- Nitto 33's.JPG (38.03 KiB) Viewed 27151 times
Build:
