offroadTB.com • View topic - Driverside Mirror Spaz Attack
by CHIEF BIG RIDGE » Wed Sep 12, 2012 11:07 am
As the title states the driverside mirror likes to spaz out, every once in a while, when I unlock the car with the remote. I know that there are settings for driver 1 and 2 so I made them both the same since I'm the only one who drives it. Yet it still freaks.
What is the real problem here?
Andrew
CHIEF BIG RIDGE
by 06MidnightBlue » Wed Sep 12, 2012 11:37 am
Electrical short?
06MidnightBlue
by v7guy » Wed Sep 12, 2012 8:33 pm
Electrical gremlin... you broke two of the three rules, you obviously got your Mogwai wet and fed it after midnight.
I know from first hand experience loose/corroded grounds cause all sorts of wierd problems
What exactly do you mean by "spaz out"?
Does it do it when you push the unlock button and that's the only time?
Does it adjust normal with the switch?
Gotta be a lot more specific to get help.
May also want to try gmtnation since there are a lot more experiences over there.
by The Roadie » Thu Sep 13, 2012 2:33 pm
Well-known problem with aging mirrors due to poorly-sealed position feedback sensors. You can upgrade the mirrors or disable the function, but I'm not actually certain how to disable the function without also killing the power remote function.
GM got so sick of warranty and extended warranty expenses due to this issue they ended up changing the BCM software in later years of the two-driver memory function to quit adjusting the mirrors.
by CHIEF BIG RIDGE » Thu Sep 13, 2012 6:56 pm
I appreciate guys. I'm probably going to upgrade and throw on some larger mirrors for towing.
Andrew
CHIEF BIG RIDGE
by Cody_S » Thu Sep 13, 2012 7:35 pm
I had a problem where, even though both memory functions were set the same, it'd move every time I unlocked. Found a way to disable it by going through some of the DIC settings. So if you have the DIC on your truck, you may be able to disable the memory feature.
WX4WCS
Cody_S
by hobbstisdaman » Sun Sep 16, 2012 12:33 pm
I had mine move all the off the motor once... For whatever reason it moved so far to the outside that it caught and wouldnt move any more. Had to pop it into place
Shoot, Move, Communicate.
hobbstisdaman
Return to Electrical / Radios
