by Lauron » Thu Jun 14, 2012 12:14 am
Brent, my son(an automotive technician) and I are installing Mark's three inch lift. While assembling the second strut using a wall mounted spring compressor, we noticed the amount of threads exposed was less than the first one assembled and the strut was offset and cocked slightly. We disassembled the strut and found the inner steel bushing spacer had hung up on the 3" aluminium spring spacer/mount. This meant the lower rubber bushing had not been compressed even though the strut nut was tight and the upper bushing was very compressed. We used an impact gun to tighten the strut nut.
Considering we were using the wall mount compressor, where the spring is compressed evenly, the strut still hung up.
For your 2" lift, I suspect the upper strut mount is hanging up on the strut threads or the shoulder past the threads as you assembled it. The fact the strut is offset in your pics looks the same as we saw plus it looks like you don't have full thread make up.
The movement you show in the video indicates it is free. You should now be able to tighten the strut nut and compress the lower bushing. I would recommend raising the lower control arm to take up the play and make tightening easier. It should also reduce the chance of further binding.
If this doesn't work then disassembly and reassembly compressing the spring as much as possible to expose as many of the strut threads as possible is what you need to try get. Even with the wall mount, it was a challenge.
Good luck,
Ron
Build:
