Radflo Custom OEM replacement Coilovers
Products offered by our vendor: OregTrailBlazin
Moderator: OregTrailBlazin
by HARDTRAILZ » Wed Mar 21, 2012 11:44 am
Would love a set but not sure I can justify them.
by navigator » Wed Mar 21, 2012 12:40 pm
come on Kyle, you know you need a set. You need a set worse than ..... chrome rims.
Mike is getting a set.... :raspberry:
by HARDTRAILZ » Wed Mar 21, 2012 12:57 pm
They cost more than 2 sets of chrome wheels
by bartonmd » Wed Mar 21, 2012 1:48 pm
navigator wrote:come on Kyle, you know you need a set. You need a set worse than ..... chrome rims.
I'm -likely- getting a set because I haven't gotten a full lift yet, because the dampers are better, because the ride height/preload is adjustable, and because they'll end up costing me ~30% less than what I pay for them... Can't REALLY advertize offroad gear without having a lift, now can I? :finger:
by OregTrailBlazin » Thu Apr 05, 2012 5:53 pm
They are ready to build them. About a week lead time, and will run $995 shipped. I'll do a special hook up for the first five that order. These are built to order, so valving and spring rate can change, but price will be the same.
Drop me an email if you are interested
Johnny@wheelersoffroad.com
Johnny Kurz
General Manager
541-474-2879
Wheeler's Off-Road Inc.
Our Vendor Section
OregTrailBlazin
by bartonmd » Thu Apr 05, 2012 6:47 pm
Email sent.
by hobbstisdaman » Fri Apr 06, 2012 8:46 pm
So would this (with price in mind) even provide a MUCH better alternative than buying oem springs such as 88's and bilstein HD shocks?
hobbstisdaman
by bartonmd » Mon Apr 16, 2012 1:59 pm
Ordered!
by fishsticks » Mon Apr 16, 2012 3:24 pm
hobbstisdaman wrote:So would this (with price in mind) even provide a MUCH better alternative than buying oem springs such as 88's and bilstein HD shocks?
This is front lift/stiffer springs (stiffer than 88s)/new shocks all in one package.
At least $400 for all that if you went the cheap route and could actually FIND 88s anymore. $700-800 if you go for the more expensive lifts.
If I had it to do over again, I'd be looking seriously at these.
by bartonmd » Mon Apr 16, 2012 3:51 pm
Yeah, that's kind of my thing, too... Plus, I've already got the Bilstien HD, and even they're tuned for stock tires and weight, so my 10-ply tires skip when I hit a bump in a corner, etc. etc... Much better dampers, adjustable preload/height, stiffer spring, etc. etc. etc...
I learned when I completely re-valved the front end of my bike, and put an Ohlins on the rear, that aftermarket dampers are MUCH, MUCH BETTER than anything stock...
by Trail X » Mon Apr 16, 2012 5:23 pm
Looking forward to seeing these and hearing your thoughts Mike.
by bartonmd » Mon Apr 16, 2012 8:19 pm
JamesDowning wrote:Looking forward to seeing these and hearing your thoughts Mike.
I look forward to seeing them and having some thoughts about them!
by OregTrailBlazin » Tue Apr 24, 2012 1:47 pm
First set of TB specific RadFlo coilovers are in production. Mike should hopefully see them sometime next week.
Johnny Kurz
General Manager
541-474-2879
Our Vendor Section
OregTrailBlazin
by HARDTRAILZ » Tue Apr 24, 2012 2:01 pm
Sweet action. Can't wait for him to get them and be able to are them.
by bartonmd » Wed Apr 25, 2012 9:19 am
PERFECT!
by bartonmd » Mon May 21, 2012 6:09 pm
MWAHAHAHAHA!!!
They showed up today!
The spring is 600#, BTW:
They won't get mounted until tomorrow at the very earliest, but they're here!
by DirtyBacon04 » Mon May 21, 2012 6:27 pm
Mmmmm perrrty.... I hope they came with stickers!
by bartonmd » Mon May 21, 2012 10:11 pm
From a quick drive around, WOW, these are great! They're a 600#/in spring, which is quite a bit stronger than the "87" springs, but they feel about the same running down the road (which is to say, pretty good/smooth). Where the Bilstein HD/87 combo would let the tires skip over mid-corner bumps, these seem to stay pretty planted. I ran up and down my buddy's rutted up driveway and road, and they soaked up the bumps really well, without upsetting the chassis. Soaked up the couple BIG bumps really well!
Also, I had told them what I had done (1/2" spacer + 87 springs = ~1.5" lift), and said that for right now, I wanted them right around there, to maybe 1/2" taller. After driving a few miles on them, I'm right at 1/16" taller than I was (35") without the winch, with more than enough room for more preload to max it out, as well as to go down to stock height.
by HARDTRAILZ » Mon May 21, 2012 10:24 pm
Sweet action!
by snowmirage » Mon May 21, 2012 10:27 pm
Very cool, certainly something to consider.... hmmmmm
snowmirage
Return to Wheeler's Off-Road Inc
