washers from mark mc lift
by oc3273 » Tue Feb 28, 2012 12:47 pm
I bought a used markmc lift that had no washers with it, now I'm starting to realize that's a bigger deal than I thought. Does anyone know if I can use the stock washers, modify them or not use them at all? I had put aside ths weekend to get this done as I just got all shocks and struts delivered I would like to stick to that plan.
Thanks for any help guys,
Dave
oc3273
by v7guy » Tue Feb 28, 2012 12:57 pm
The 2.5" lift or the 3"?
by navigator » Tue Feb 28, 2012 12:58 pm
in his instructions it says you need to use the new washer.
PM Mark, he may sell you just the washers or tell you what size you need to pick up at the hardware store.
http://theliftmeister.com/public_html/t ... ctions.pdf
by HARDTRAILZ » Tue Feb 28, 2012 3:28 pm
You can mod the ones you have. Mark had to do it for awhile when he couldn't get the right ines from anywhere.
by oc3273 » Tue Feb 28, 2012 8:50 pm
Its for the 2.5 lift, anyone know what I would have to do mod them since I have no Idea what they are supposed to look like. In the meantime I will pm mark. Thanks guys
oc3273
by markmc » Wed Feb 29, 2012 4:32 am
oc3273 wrote:Its for the 2.5 lift, anyone know what I would have to do mod them since I have no Idea what they are supposed to look like. In the meantime I will pm mark. Thanks guys
i buy them special made, so i doubt you will find them at any hardware store..
One option is to purchase a couple sets of Monroe upper mount kits from local auto parts, they will have the smaller washers you need..
And you might as well replace the upper mounts while you have the assembly apart anyway..imo..
Soak your upper and lower strut mount nuts with penitrant asap!! PB Blaster works best..
markmc
Rank: Mall Rated
by hobbstisdaman » Sat Mar 17, 2012 12:01 am
Mark is your 3" suspension lift exactly 3" on front and rear? Or is there a leveling factor?
hobbstisdaman
by djthumper » Sat Mar 17, 2012 2:12 am
3" front and rear it is not marketed as a leveling kit. http://theliftmeister.com
by hobbstisdaman » Sat Mar 17, 2012 10:52 am
So the front end will still sit lower than the rear.
hobbstisdaman
by Cable810 » Sat Mar 17, 2012 12:42 pm
hobbstisdaman wrote:So the front end will still sit lower than the rear.
It shouldn't. Browse the Build Threads there are a few guys that have the 3" without new springs viewtopic.php?f=25&t=2073
by navigator » Mon Mar 19, 2012 4:14 pm
it is 3 inches front/2 inches rear.
I think our rear is 1-1.5 inches taller than the front.
So it should be pretty level or a small amount of rake.
