I figured one night that all "business" comes from above...so I wanted to somehow mount my CB to the ceiling. The original plan was to mount it in/on the voice recorder and garage opener...but it was too honky and blocked the rear view mirror. Then, over the phone, it evolved into getting a small piece of metal and fixing it to one of the screws that hold the voice recorder/garage opener thing to the ceiling, allowing it to rotate so both driver and passenger could view the radio. However, that would require us to punch through the ceiling and...well, that was just a horrid idea. Then Dave figured we could remove the sun visor and mount it with the existing hardware somehow.
I wanted to use my existing Laird Whip, but mount it in the back of the TrailBlazer - kind of like what most of you guys have...just not punching through the side of the truck or using the "contact method." So, we figured we would mount it to the tail light or metal are above the tail light. It would keep it "lower" yet high enough so I could still get out to talk to my locals.
Somehow...my Midland 1000Z Blew up. When we hooked it up to test it, all you heard was a loud whining on the other end...no TX audio at all. So, since I had no other options, I put my 19DX in there which is over modulated since I broke the modulation adjuster on the board
; that's why you see two different radios down there:Well, here are the photos - Captions are below the photos:
You can see here that we fed the Coax through rear of the tail light...
How the coax entered the interior...we fed it along the side.
Dave attempting to drill into the mounting area...with a wood bit...my fault; whoops. Bent bit below:
Close up of the Finished mount
Far off shot
INTERIOR
Where we brought the coax through
The CB - mounted where the visor used to clip into place
The really crappy sounding 19DX...
We fed the electrical across the top of the headliner, and down the driver side door area. We then fed it through the internal fuse box. I have a nasty alternator noise...I guess the 19DX isn't set to filter that out...or we did something wrong.
Finally...my not so complete VHF:
I got sick of the Johnson; the speaker was blown and it's receiver was dirt. So, I threw my trusty Spectra in there. We had to break the area in which we mounted it, but Dave put a screw into place to hold it - pretty clever. The only reason it is not complete is because I don't know how to wire it to the ignition - I'll make a Troubleshooting post on it soon. I plan to mount the VHF antenna to the opposite area above the tail light - It just seems more practical and allows me to pull this under the carport.
As time progressed...the camera became less and less of a priority and our patience began to become tested. Happy this is squared away now. I can't wait for the ribbing I'll get tomorrow when I jump in with the locals on 19.
