so the parts came in today.
All the bushings are in sleeves. The old sleeves need to be pressed out of the A arm and the new bushings need pressed in. Basically this is probably going to be a massive pain in the ass for anyone without access to a press. Before I use a press I'm going to try a few home garage solutions first. My initial impression is that you would probably be better off just buying the A arm as many members have done before. This isn't going to be as simple as burning out the old bushing, cleaning the sleeve, and inserting the new bushing like is common with poly bushing upgrades.
I may sing a different tune after I'm done, but I'm skeptical.
Here's some pics...
2500HD inner and outer tie rod end (thanks for discovering this Donny) find the thread here...
Picked up some timken hubs. I've used cheaper hubs in the past and had to replace them swiftly. When I replaced the hubs in my firebird that's running a 18x11 wheel with 315 35 18 tires the Timkens held up the best, the cheap hubs were garbage in a couple months. Experience has taught me that you should spend a little more in this area. I didn't spring for the SKF hubs, but I was tempted. The timken hubs look nice and I wouldn't hesitate to recommend them.
I already had a duralast ball joint and I was going to use it. But after seeing the MOOG and comparing the two I think I would spend the money on the MOOG if I had the two option in front of me. The lip is significantly thicker on the MOOG, and the tolerances are better. The MOOG takes a lot more pressure to move the joint around. They both have grease fittings, and they both are drilled for a cotter pin. I'm leaning towards running both and seeing how they hold up.
