by navigator » Tue Jul 24, 2012 4:08 pm
for my rack I took a round washer and cut two sides off of it to make it fit snug in the track.
I then used a bolt and tightened a nut down real tight on the washer so it wouldn't slip. The result is the washer sandwiched between the bolt head and nut. It fit in the track tight enough that it wouldn't turn and I could then stick it up through my roof rack and tighten down with another washer and nut. I've only had one issue with them because my washers weren't heavy enough but it proved the concept to me. Next go round is heavier washers.
