offroadTB.com • View topic - Light Bar on roof is loud
by Mudwheelin » Fri Jul 29, 2011 1:03 pm
Hey guys and gals.
I followed the how to on the "DIY Light Bar" to a tee. It is very loud when traveling 60km (Canadian) and over. Has anyone else had the problem with noise. Its like a whistling windy noise and very annoying. Any advise on how to quiet the noise down? Everything is tight :scratch:
Build Thread:
viewtopic.php?f=25&t=2349
Mudwheelin
by Trail X » Fri Jul 29, 2011 1:09 pm
Do you have caps on the ends of your tube?
by Mudwheelin » Fri Jul 29, 2011 1:19 pm
Build Thread:
Mudwheelin
by navigator » Fri Jul 29, 2011 1:32 pm
if you have some holes maybe fill them with silicone or something to seal them up. I think most have just used tie wraps and secured them to the outside of the bar.
by janesy86 » Fri Jul 29, 2011 1:33 pm
Yea, it most likely could be that hole. I had a light bar on top for a while, have since taken it off but when I first made it (4 lights), there was no excess noise coming from it. Then a light went out, and instead of fixing it, I made it a 3 light bar, so I drilled new holes. Noise came from them till I plugged them. Then all was well again. So maybe put some silicone over the hole seal it better and see if you have any luck?
by Gordinho80 » Fri Jul 29, 2011 1:35 pm
Go all out... remove one of the caps and shoot the tube with expanding foam... let it dry then shave off any excess from that hole and put the cap back on.
Mario -
by Mudwheelin » Fri Jul 29, 2011 1:35 pm
Build Thread:
Mudwheelin
by NC_IslandRunner » Fri Jul 29, 2011 9:35 pm
when I had mine on it didn't make much noise either, the only holes in my bar other than the ends I drilled for the lights. did you use tube with holes already in it?
by Mudwheelin » Mon Aug 08, 2011 6:05 pm
Hey guys.
So over the weekend I filled the 3 holes in the lightbar that I drilled for running the wires through. It still makes noise :shoot: If the noise wasnt so loud I wouldnt worry about it but it seems WAY louder then it should. Any other ideas would be great... I made sure that I filled them really good.
Build Thread:
Mudwheelin
by Trail X » Mon Aug 08, 2011 6:27 pm
It may be easier to diagnose if you post up some detailed pictures of your work.
by The Roadie » Mon Aug 08, 2011 7:07 pm
by Mudwheelin » Mon Aug 08, 2011 7:25 pm
Lol, like I said."Any" ideas would be great. I will take a few pics when I get home if its still light out. Ill take them either way... ill be back on in a couple hours with pics. Thanks for your help so far. :friday:
Build Thread:
Mudwheelin
by Mudwheelin » Mon Aug 08, 2011 9:30 pm
[attachment=0]Copy of DSC03965.JPG[/attachment]
It will only let me do 3?
Build Thread:
Mudwheelin
by Mudwheelin » Mon Aug 08, 2011 9:32 pm
Heres some more..
Build Thread:
Mudwheelin
by Mudwheelin » Mon Aug 08, 2011 9:38 pm
And just some nice ones.
(19.95 KiB) Downloaded 178 times
(19.12 KiB) Downloaded 178 times
Build Thread:
Mudwheelin
by Trail X » Tue Aug 09, 2011 9:01 am
Try sliding it forward on the roof, so your 1" mounting bar (that's inside the roof rack rail) is butting up against the aerodynamic front cover of the roof rack. It's possible that gap is causing your whistle.
by Mudwheelin » Tue Aug 09, 2011 9:25 am
Thank you. I will give that a shot around noon. Ill have to loosen the wires somewhere in the interior to give it that extra couple inches lol. Ill let you know how it goes.
Build Thread:
Mudwheelin
Return to Fab Work
