electrical issue
by TangoBravo » Thu Apr 14, 2011 8:35 pm
So the wife was driving the TB yesterday and told me the the guage clusters all went dead, the radio got interrupted but stayed on. However the time went to 12:00. My stations stayed programmed and everything did fix its self. But today after I corrected the time it got messed up again. I checked all the obvious things and just can't figure it out. Everything works fine as of now but I would like to fix the problem. Anyone have suggestions?
TangoBravo
by rjpoog1989 » Thu Apr 14, 2011 8:39 pm
I've had this same problem for a while. It does it once every month or so, resets the clock and whatnot. Still searching for clues towards the answer...
Ryan
rjpoog1989
by TangoBravo » Thu Apr 14, 2011 9:52 pm
Ok well I guess I will keep an eye on it. Untill we can get it figured out.
TangoBravo
by The Roadie » Thu Apr 14, 2011 10:04 pm
My spidey-sense smells ignition switch.
by TangoBravo » Fri Apr 15, 2011 5:43 am
The Roadie wrote:My spidey-sense smells ignition switch.
That could cause the clock to 0 out and the gauges to malfunction? I don't know much about vehicle electronics. Also is there a way to test the ignition switch myself?
TangoBravo
by bgwolfpack » Fri Apr 15, 2011 10:52 am
You may not want to question theroadie advice on this subject. He's posted about this subject one or two times on the OS. :cheers: He also can tell you what brand to buy and from whom or link you to ebay if willing. :work:
by TangoBravo » Fri Apr 15, 2011 7:00 pm
Of course this is the roadie were talking about ( palm to face). So i will look into how to test the ignition switch then. Thanks for the advice guys.
TangoBravo
by The Roadie » Fri Apr 15, 2011 7:33 pm
For the $30 it will cost at the aftermarket stores, it's pretty much not worth your time to try to test it. Unless the intermittent failure turns into a permanent one. The failure rate is horrible, and if it's not dead now it will be later on, and I predict it will be 20 miles from pavement. It's even more vitally important for an offroader to have a reliable switch than a mall queen. I changed mine out when it showed the FIRST hint of failure, and I bought a spare on Ebay for $5 and carry that around to sell for $100 to somebody who didn't carry their own spare 20 miles from pavement. :finger:
But if you DO want to throw a voltmeter on it:
RED on the ignition switch is 12V, fused by underhood fuse #34, and feeds the following three circuits:
White is hot in ACCY, RUN, START
Orange is hot in RUN
Yellow is hot in START
RED/WHITE is another 12V, fused by underhood fuse #36, and feeds two circuits:
Brown is hot in ACCY, RUN
Pink is hot in RUN, START
That said, you could always have a flaky battery or fuse block wiring, because the radio does NOT have switchte power. It gets fed straight from the battery and gets turned on and off by a data packet from the BCM.
But unless and until you have a known-good ignition switch, the fault could be as subtle as the ignition switch confusing the BCM and causing an odd reset.
by rjpoog1989 » Fri Apr 15, 2011 7:38 pm
I will be looking into this as well. The ignition switch is a probably my issue, based on other problems I've had with the vehicle, it makes complete sense! :D
Thanks all!
Ryan
rjpoog1989
by TangoBravo » Sun Apr 17, 2011 12:29 am
Yeah that's awsome details Roadie thanks. I think I will do the smart thing and just replace it. where I do most of my wheeling is an hour and a half down an unmaintained paved road just to get to the first trailhead. So needless to say even if I broke down on the pavement there is still nothing around.
TangoBravo
