offroadTB.com • View topic - Having 2 spacers in the front end?
by DmccartneyFF2TB » Sat Nov 06, 2010 11:57 am
Would having a 2 inch rough country spacer on top and a susp maxx on the bottom work any one ever try? I wanted to just get stiffer springs but i still want to keep some travel in the front end. I dont know just a thought.
Dame
BDS,ROUGH COUNTRY,
Smitty Build XR-C8 Winch
www.wm4x4.com
DmccartneyFF2TB
by MrSmithsTB » Sat Nov 06, 2010 12:19 pm
Check out fishsticks thread on flipping UCAs. It won't work because of the lack of space. The LCAs can't provide enough extension to allow fitting that much outside of strut spacer, and with your CV joints may bind. The stiffer springs provide the only safe way to really get more front lift.
by TangoBravo » Sat Nov 06, 2010 1:26 pm
So how much lift are you looking at outside the strut? I have 3" outside no binding issues, my ball joints are doing well. I am happy to report that I have no bad side effects from having 3" outside the strut. In my opinion adding stiffer springs without having extra weight in the front just to achieve lift is not completly safe like some will lead you to believe. With that being said it can be argued that anyway we modify our vehicles insn't the safest thing. In the end I have a nice comfy ride it feels stock but is lifted 3".
TangoBravo
by DmccartneyFF2TB » Sat Nov 06, 2010 1:40 pm
Dame
BDS,ROUGH COUNTRY,
www.wm4x4.com
DmccartneyFF2TB
by bartonmd » Sat Nov 06, 2010 4:01 pm
by fishsticks » Sat Nov 06, 2010 6:39 pm
by DmccartneyFF2TB » Sat Nov 06, 2010 9:19 pm
Yea i wanted to go with 87s but i still want some wheel travel. So i figured if there are just 2 spacers i would still have the same wheel travel with the springs i have now and still get the same lift if i where to put 87s in. I dont know i could try it they both cost the same any way.
Dame
BDS,ROUGH COUNTRY,
www.wm4x4.com
DmccartneyFF2TB
by fishsticks » Sun Nov 07, 2010 12:13 am
by bartonmd » Sun Nov 07, 2010 12:31 am
by TangoBravo » Sun Nov 07, 2010 12:37 am
To each there own, I have maxed my travel both on compression and totally unloaded and I have no binding everyone speaks of. But I seem to be the only one running this set up so I guess Im out front on this one. I hear alot of people say what my type of lift should do or that it might do this or that, But I like mine and have had no problems from it. However my lift is one piece it isn't split up or anything I have a 3" blocks in rear and 3" for lack of better words above strut spacer in the front. From start to finish I was done with all four corners in just over 2.3hrs no taking apart the strut needed. Plus this type of lift works best for what I do as where stiffer springs would not.
TangoBravo
by bartonmd » Sun Nov 07, 2010 12:45 am
by fishsticks » Sun Nov 07, 2010 12:46 am
by TangoBravo » Sun Nov 07, 2010 12:51 am
Ok I will shut up then, I am lost tonight possibly looking at too many things at once
TangoBravo
by DmccartneyFF2TB » Sun Nov 07, 2010 2:18 pm
Ok well not im lost haha well i am going to just go with springs a body lift and larger tires..
Dame
BDS,ROUGH COUNTRY,
www.wm4x4.com
DmccartneyFF2TB
