Oil Pan Question
by kodachrome9319 » Wed Nov 03, 2010 8:07 pm
Is there any new oil pans for the 4.2L that have some kind of baffle in it to prevent the engine from being staved of oil when going up a hill? Nearly shit myself when my dash looked like a disco ball going up a nice incline last week, and just remembered to asked.
Thanks guys.
kodachrome9319
by HARDTRAILZ » Thu Nov 04, 2010 8:46 am
I have not seen anything or had that issue, but I have had the fuel pump not seeming to have the pressure to pump up at full throttle steep climbs. What lights went off and did you have the oil filled?
by kodachrome9319 » Thu Nov 04, 2010 5:31 pm
HARDTRAILZ wrote:I have not seen anything or had that issue, but I have had the fuel pump not seeming to have the pressure to pump up at full throttle steep climbs. What lights went off and did you have the oil filled?
Oil level is full, dirty, but full... I got the "Check Gauges", the Check Engine, and my oil pressure gauge dropped really quick... My thought is that going up the hill, the oil pickup couldn't get any more oil since it all sloshed to the back.
I'll get this oil change this Saturday (hopefully, my grandfather is in critical care after having a ruptured abdominal aortic aneurysm this morning and surgery fixed it) and we'll see if that fixes my oil issue...
kodachrome9319
by Trail X » Thu Nov 04, 2010 5:36 pm
How steep of a grade? Seems like it'd require a very steep climb to move all that oil away from the pickup.
by kodachrome9319 » Thu Nov 04, 2010 5:42 pm
JamesDowning wrote:How steep of a grade? Seems like it'd require a very steep climb to move all that oil away from the pickup.
I honestly have no idea how steep... It was a continous grade, about 500 feet on some slick dry grass.
Something inside of me wants to say 45 degree +/- some, but like I said, honestly, not a fricken clue.
kodachrome9319
by KE7WOX » Thu Nov 04, 2010 9:47 pm
I've noticed drastic changes in the gauge in really steep inclines (normally found on forest roads), but never to the point of getting lights and warnings all over the instrument cluster.
KE7WOX
by gotspeed1 » Thu Nov 04, 2010 10:49 pm
I can't answer your question, but I can confirm having this happen as well. Something to the effect of "shut off engine" has came up on the DIC twice while going up a steep incline.
gotspeed1
by bartonmd » Thu Nov 04, 2010 10:54 pm
It does make sense... Most vehicles have a sump in the rear of the engine, and have oil pressure issues from stopping or going DOWN steep hills... I gather that because of where our diff is, our sump is in the front of the engine, which causes oil to sit on the shelf at the shallow part of the pan, when you're pointing up hill too steep for too long...
by BSalty » Fri Nov 05, 2010 12:12 am
:Iagree: Just out of curiosity could you hear the crank slapping the oil? I had that problem in my T/A when I would auto-x hard on braking. You could hear it cavitating in the oil, and it had a baffle.
BSalty
by The Roadie » Fri Nov 05, 2010 8:47 am
Happened to me a couple times in Moab, in the slickrock sandstone fins in my Youtube videos.
Return to Off Road Discussion
