offroadTB.com • View topic - Broken exhaust manifold studs ftl
by midnight » Thu Aug 12, 2010 8:16 pm
So I have started hearing a ticking sound from the passenger side of the motor when started cold. It goes away after a minute of driving. So I finally get brave enough to get out in the 200' heat to take a look. The back two bolts are broken off at the head. I am afraid to find out how much this is going to cost me. Is this common and what the hell causes it?
midnight
by Trail X » Thu Aug 12, 2010 9:51 pm
If they are torqued down too far, they can pop when the manifold expands.
It's possible that your manifold was taken off sometime and not torqued properly. How much of the screw shank is visible? If it broke close to the head, it may not be impossible to remove. They are stubborn to remove - even with the head on.
by midnight » Thu Aug 12, 2010 10:23 pm
I have owned it from about 50k miles. So it had to have been done before then. I did some reading saying that they used grade 5 bolts on them. Which means I will be replacing with grade 8 when I fix this.
Way to save $3 chevy.
midnight
by Trail X » Thu Aug 12, 2010 10:37 pm
Careful - Grade 8 are stronger, but also more brittle.
If GM specifies grade 5, it's probably because they "stretch" better, which is needed in high-heat variation areas like headers. Your bolts have to expand and contract properly with the header flange. This is one place where I would probably buy genuine GM parts or other bolts specified for headers.
by midnight » Thu Aug 12, 2010 10:43 pm
Good point James.
midnight
by glfredrick » Fri Aug 13, 2010 1:09 pm
== The United Christian Off-Road Alliance, a family friendly place
glfredrick
Contributing Author
by Trail X » Fri Aug 13, 2010 1:39 pm
You're talking stress only... you need to bring strain into the discussion.
Below is a stress/strain graph for a few grades of bolts.
The grade 8, as you can see is stronger (higher max Y), but the fracture point is almost half of the elongation of the grade 5 (x axis - less X axis means more brittle). This may not matter over a few heat cycles of the exhaust, but every time you're stretching the bolt, you're fatiguing the bolt. So over more displacement cycles, you're fatiguing the unstretchy bolt more than the stretchier bolt.
This is the case in this situation because the flange is expanding a certain displacement each time it heats up. If you're just imparting force and not displacement on the bolt head, then it makes sense to go with a stronger bolt (grade 8).
by Philberto » Fri Aug 13, 2010 2:07 pm
Why do I have a feeling that James had that graph lying around somewhere?
by fishsticks » Fri Aug 13, 2010 2:55 pm
by midnight » Fri Aug 13, 2010 4:43 pm
he carries it around like a gun. ready to draw at anytime.
midnight
by HARDTRAILZ » Sat Aug 14, 2010 9:59 am
There is a very specific tightening sequence to the exhaust manifold. I was told by a couple mechanics that you need to torque them down 5-7 times and it is weird because they torque to the 15 lbs or whtever it is then by the time you follow the sequence and go back to check you have to re-torque. I definitely would use factory parts and follow the proper instructions.
FYI--I discovered this since my O2 sensor was stripped and was worried about breaking manifold bolts to figure a way to get it out.
by glfredrick » Sun Aug 15, 2010 3:07 pm
I agree with the stresses that James posted with one caveat... The grade 5 bolt will have already broken -- even at peak stress capability -- before the Grade 8 even starts to work.
glfredrick
Contributing Author
