offroadTB.com • View topic - New Springs... 88's
New Springs... 88's
by HARDTRAILZ » Thu Aug 05, 2010 9:39 am
My hub to fender is 26ish, or was. Need to remeasure that one again. So 23 without body..minus stock 18.25 so 4.75 suspension??? WOW
by MrSmithsTB » Thu Aug 05, 2010 12:12 pm
by HARDTRAILZ » Thu Aug 05, 2010 12:42 pm
I had 82's
by fishsticks » Thu Aug 05, 2010 12:48 pm
by HARDTRAILZ » Thu Aug 05, 2010 12:52 pm
I may drop it back down some, but figued itwas worth trying. I want ground clearance more than anything else. Our suspension is not exactly great offroad in any configuration.
by fishsticks » Thu Aug 05, 2010 12:55 pm
by HARDTRAILZ » Thu Aug 05, 2010 1:09 pm
Yep. Trying to get enough before just trashing it, but everything you do has an other side of the coin.
by HARDTRAILZ » Mon Aug 23, 2010 11:07 am
Well an update...
Was up just over 42 ground to fender and the cv angles worried me some, so i pulled out the outside strut spacer and it was down to about 41 3/8s. Then i beat the hell out of it offroad and I now have a height of 40.5ish. However it rides better and alignment issues are not as present. I may add the extra spacer back in now. Not sure, but everything seemed to work fine and no leakage or cv boot issues still. Mine are still stock with mo mods.
by fishsticks » Mon Aug 23, 2010 11:19 am
Mine settled in .5" after bouncing around yesterday as well. I think I'm ready to try aligning now, as I still have positive camber.
by HARDTRAILZ » Mon Aug 23, 2010 11:32 am
Mine have come down an inch so you may want to wait on the alignment. i have very little pos camber now.
by janesy86 » Wed Sep 29, 2010 8:00 pm
Kyle and others that have upgraded their springs, just wondering what your running currently...
Did you put the Marks outside spacer back in? Whats your CV and UBJ angles look like currently? Flipped control arms?
I ask this because I have 87's on the way and am trying to figure the best configuration to run w/o having to break it all down multiple times, since TECORE is coming up soon.
by HARDTRAILZ » Wed Sep 29, 2010 8:25 pm
I am running flipped without the extra spacer, but the spacer is going back in since the springs settled. Just waiting for my sciatic to calm down to reinstall. The angles dont look bad and it did fine wheeling it hard.
by janesy86 » Wed Sep 29, 2010 9:02 pm
Awesome, thanks man! Thats exactly why I wanted your advise since you run Marks lift and take your Tb to the limit.
by HARDTRAILZ » Wed Sep 29, 2010 10:29 pm
The angles did look pretty steep on the shafts til I beat the springs to settled. It seems they have not dropped any more, so I now feel comfy adding the spacer, but at first I thought it was too much. Just the outside spacer is easy to add later if you try without it til they settle.
by janesy86 » Wed Sep 29, 2010 10:46 pm
Good call. Thanks man.
