offroadTB.com • View topic - looking swap info
looking swap info
by jdmser » Fri Jun 16, 2017 11:40 am
I've been searching and all I seem to find are "it can't be done" or "the swb has a different frame" threads or "go search" threads. I have a 03 EXT with the 4.2 and want to go to a built 5.3 or fresh rebuild lq4. I'm done with the 6 so turbo,build,supercharged is out of the question. Where should I look for info where people actually know what they're talking about?
jdmser
by mason10198 » Fri Jun 16, 2017 2:43 pm
There is one person here I know of who has done it, because I remember he spent forever on the wiring nightmare. Can't remember who it was though... You should be able to find that thread with a search.
| Mason | | | |
by AWCougar » Sat Jun 17, 2017 9:19 pm
There have been a few people that have done the 5.3 swap. Gmtnation has a lot more on the swaps because of its more diverse crowd
"Though we have heard of stupid haste in war, cleverness has never been seen associated with long delays." -Sun Tzu
viewtopic.php?f=74&t=5821
AWCougar
by CHEVELLE598BB » Mon Jun 19, 2017 1:41 pm
I have done numerous ls swaps. They aren't bad if you have access to good wiring diagrams. I haven't swapped an envoy or trailblazer yet but I have everything ready too. Unless i talk myself into doing a Cummins 2.8 four cylinder turbo diesel swap. Not sure yet. Im waiting for my 4.2 to die.
CHEVELLE598BB
by rayluniewski » Tue Sep 05, 2017 9:05 pm
The rainiers and saabs had a 5.3 short wheelbase option.
rayluniewski
by bartonmd » Thu Sep 07, 2017 7:56 am
As long as you're swapping in a gen-3 small block, you just have to change the wiring for the engine/ECM/TCM. If you're going to an LH6, they're CANbus, and you have to swap basically the whole wiring from the donor vehicle, inside and out. The frame is just cutting where the trans crossmember mounts and welding it back a couple inches farther forward, then new drive shafts, swap the rear end out from the donor (8.6 vs 8.0), and of course the radiator/shroud, and the bell housing for the trans. IF you have a complete donor V8 TB, it's just swapping parts and wiring and stuff over, and some welding. If you're trying to piece it together, it's a lot harder.
by jdmser » Sat Sep 09, 2017 9:33 am
Do either the Silverado or swb harness' work in the EXT or are they all proprietary?
jdmser
by bartonmd » Mon Sep 11, 2017 12:27 pm
The Silverado almost certainly won't. The EXT harness probably will, as long as you're talking about the same year ranges.
by escapepilot » Mon Sep 11, 2017 3:07 pm
If you really want a 5.3 in your EXT, you would probably save yourself a ton of time and money by finding a junkyard EXT V8 and getting the whole thing. Then you'd have engine, mounts, radiator, harness, etc. I know the radiators are different because I had to modify the radiator brackets in Mark's 3" body lift to fit the 5.3 radiator.
Where are you located?
escapepilot
by jdmser » Wed Sep 13, 2017 9:58 am
I'm about 45 minutes west of St Louis. I've been looking for a salvage 5.3 ext for a while now. That's probably the way I'll go.
jdmser
by escapepilot » Thu Sep 14, 2017 9:54 am
escapepilot
by CCTB » Sat Jan 27, 2018 11:17 pm
I just bought an 05 4.2L engine from http://engine-transmission.com/ and it came with a 5 year warranty and all the sensors needed, however it did not come with a/c compressor, alternator, and i had to swap the flywheel, intake, throttle body, oil pan, thermostat, and water pump in order to not void the warranty
CCTB
