offroadTB.com • View topic - Bilstein 33-185552 fit without washers, etc?
by thedeadtext » Thu Sep 10, 2015 7:12 am
Any thoughts?
It will be used with radflo front and MarkMC on rear (stock springs)
thedeadtext
by Anthony Hernandez » Fri Sep 11, 2015 2:32 am
Use washers bro, recently found my rear shock had traveled to one side and almost ruined it. It's worth the $6.
by thedeadtext » Sat Sep 12, 2015 3:36 am
Required a 1/2" bolt also?
Does that require drilling out the mount?
thedeadtext
by moose1 » Sat Sep 12, 2015 8:21 am
I used a 1/2" bolt with mine plus a boat load of washers, no drilling.
moose1
by TBYODA » Sat Sep 12, 2015 9:48 am
I reused the stock bolts/washers on my skyjackers 8030's.
by thedeadtext » Tue Sep 15, 2015 7:36 am
What is length of 1/2 bolt? Like, I assume the carriage aspect of the bolt is X and the threads are Y?
I live in the middle of nowhere so seeing if I can order it vs. several 50 mile round trips to hardware store.
thedeadtext
by navigator » Sat Sep 19, 2015 12:12 pm
I re-used my stock bolt with my skyjackers. Either way your stock bolt should be the right length if you go the 1/2" bolt route. The easiest thing to do might be to go outside and measure your stock bolt.
