Coilover
by Heavyblaze » Thu Mar 18, 2010 10:29 pm
Did anybody see the coilovers on http://www.airbagit.com. They call them Hiboyz.
Heavyblaze
by The Roadie » Thu Mar 18, 2010 10:52 pm
Got a part number? All I see is this:
Highboyz Can'T Make, Use Adjusters
Highboyz adjustable coilovers
Dealers Call for Quantity pricing!
List Price: $718.80
Our Price: $599.00
You Save $119.80!
Year: 2002-2006
Make: CHEVROLET
Model: TRAILBLAZER,ENVOY,BRAVADA
Stock Status: In Stock
Product Code: X4-HI-CHE-12
What's that mean: Can't Make?
I looked at Shockwaves and annular bags five years ago. For the $2500 or so a set-up for four wheels was going to cost, they had a pretty fragile reputation. Did you call them to find out more? Could you?
I certainly don't like the way they make coilovers for the REAR that use the stock shock mounts, and not the spring perches. I had a long knock down drag out fight with Tony of tbssowners.com over that idiotic concept.
by bartonmd » Thu Mar 18, 2010 11:07 pm
Yep, I remember that! :cheers:
by Trail X » Fri Mar 19, 2010 8:40 am
I thought that I proved the stresses weren't that much greater... greater, yes, but not as much as I would have thought. Only 1.5x or so, which is probably well within the design FS.
by bartonmd » Fri Mar 19, 2010 8:52 am
JamesDowning wrote:I thought that I proved the stresses weren't that much greater... greater, yes, but not as much as I would have thought. Only 1.5x or so, which is probably well within the design FS.
FAIK, most stuff in the auto industry, on those kind of components, is designed with a 50% safety factor... If nothing's rusted away, everything was welded correctly at the factory, and you're not over-loaded, it "should" be fine... "should"
by Trail X » Fri Mar 19, 2010 9:00 am
I guess the interesting thing to me, was that an impulse load on a shock is nearly that of the constant load on the spring. It was all a SWAG, but it showed me that it was much more realistic than I imagined.
However, I don't like the idea of putting all of your rear vehicle weight in shear of a bolt. No safety element if it fails other than the bump stop.
by bartonmd » Fri Mar 19, 2010 9:11 am
JamesDowning wrote:I guess the interesting thing to me, was that an impulse load on a shock is nearly that of the constant load on the spring. It was all a SWAG, but it showed me that it was much more realistic than I imagined.
Yep, and IIRC, he was talking about the bump stop being in the shock, and being "OK"...
by OregTrailBlazin » Mon Mar 22, 2010 1:51 pm
JamesDowning wrote:However, I don't like the idea of putting all of your rear vehicle weight in shear of a bolt. No safety element if it fails other than the bump stop.
:scratch: No different than the front end of the Tacoma's, or ours for that matter, it all has one bolt in shear.... Although they are allot larger!!
Johnny Kurz
General Manager
541-474-2879
Wheeler's Off-Road Inc.
Our Vendor Section
OregTrailBlazin
by bartonmd » Mon Mar 22, 2010 2:27 pm
True, but like you noted, the ones designed to be loaded like that are not only a lot larger bolts, but on a lot stronger brackets...
