CNY Trailblazer
by Philberto » Sun Mar 14, 2010 8:06 pm
Sound clips of the glasspack? I'm kinda intrigued by the incredibly cheap cost of glasspacks, and want to know how bad the drone is on one of our vehicles.
by madmanvillain » Sun Mar 14, 2010 8:37 pm
its actually a lot better than i feared it was going to be...ill post one some time next week once it gets broken in a bit more and i need to tighten one of the clamps back up :wallbash:
madmanvillain
by madmanvillain » Thu Mar 25, 2010 2:11 pm
did a bit of simple work the last week...including my exhaust...removed the resinator and the spare tire from under the back...spare tire is behind the seat for now. removed my front bumper guard and gunna trim the inner fenders tomorrow... next thing on the list is a lift!
plan: putting in marcmc's lift wish stock tires and shocks to begin with. in the following weeks i will put new shocks in (gunna look around a bit to see what i want) and then im going to put i the z71 springs. next year when my tires are worn out ill be putting new ones on unless i find something i cant pass up between now and then
so now its just time to save up money for everything-more overtime!
madmanvillain
by madmanvillain » Sat Mar 27, 2010 12:41 am
time for poor quality photos!!!!
ill post better ones eventually
(113.53 KiB) Downloaded 118 times
madmanvillain
by Trail X » Sat Mar 27, 2010 11:52 am
Dang... who were you behind that was throwing up that much roost?
by madmanvillain » Sat Mar 27, 2010 12:30 pm
buddy of mine in his stock dakoda has terrible tires and lives by the "when in doubt power out" rule....i had to stop....theres a good half inch of mud on the whole front end.....
these are the times you wish there were hot chicks in bikinis doing car washes....damn 35 degree weather.....
madmanvillain
by madmanvillain » Sun Mar 28, 2010 3:32 pm
yet another question: due to the fact that our limiting factor is out ground clearance...and we have a sway bar under our rear axle...has anyone taken it off to see how it rides? if so how is it??? thatll give us another 2-3 inches of space under the pumpkin
madmanvillain
by HARDTRAILZ » Sun Mar 28, 2010 5:27 pm
madmanvillain wrote:yet another question: due to the fact that our limiting factor is out ground clearance...and we have a sway bar under our rear axle...has anyone taken it off to see how it rides? if so how is it??? thatll give us another 2-3 inches of space under the pumpkin
i can tel you that having front rear disconnected is still drivable but creates some pretty good body roll. If you want to try it, just unhook your rear endlinks for a couple days and see.
by Trail X » Sun Mar 28, 2010 7:01 pm
My front is permanently uninstalled for more/smoother front end articulation... but I haven't unattached the rear yet.
by HARDTRAILZ » Sun Mar 28, 2010 7:24 pm
My front is unhooked again and it really is not that noticable.
by madmanvillain » Sun Mar 28, 2010 7:26 pm
i think ill test it out next weekend...one at a time then both....
madmanvillain
by irishboy02 » Sun Mar 28, 2010 9:47 pm
Start with the front and see how it feels. Im rockin out with no front, do that and get used to it before you do the rear. Thats my $.02
2003 GMC Sierra z71
7" FTS lift
irishboy02
by MrSmithsTB » Sun Mar 28, 2010 10:35 pm
Welcome. Hell of a list you got there. And I'm loving the mud. Don't mind me, I lifted so high that I ended up lowered. :friday:
by madmanvillain » Mon Mar 29, 2010 12:50 am
another question....body lift...how much stuff (lines etc) need to be replaced? and at what height? can i put a one inch without replacing lines? two inch?
madmanvillain
by The Roadie » Mon Mar 29, 2010 2:31 am
If you bash the rear on enough rocks, it will tuck up nicely exactly even with the differential. Won't hang down. Difficult to find just the right kind of ledge that will hit the bar and not put the driveshaft ujoint at risk, but somehow I managed to do it.
There are only two commercial body lifts - BDS 2" and MarkMc 3". Neither one of them needs new lines or wiring, just a steering extension, included with the kit. And some care making sure the brake lines are bent carefully.
