offroadTB.com • View topic - help quick, body lift rear bumper install
by SmokeyMcBlazer » Mon Dec 29, 2014 4:31 pm
marks pics aren't great and it seems my brackets are differnt then the ones pictured. anyone with pics or help? its all taken apart now
SmokeyMcBlazer
by Grimor » Mon Dec 29, 2014 5:43 pm
post some pics of where you're at and I'll try to give you whatever guidance I can.
do your brackets look like the ones on the left?
there should of been a sheet of modified instructions with your kit for the new brackets. they are different than the instructions on the website.
it was remove rear bumper, cut off each arm on the bumper some amount (you will cut off one of the stock welded on nuts on each arm) Then you just notch the frame rails so the brackets and bumper arms will fit 3" higher
Grimor
Rank: Driveway Rated
by SmokeyMcBlazer » Mon Dec 29, 2014 7:45 pm
Yeah bro, those are the brackets. I didn't see any extra instructions but that doesn't mean they weren't there tho.
I didn't see your reply before the action though. We ended up trimming some metal from the bumper, basically on the part of the bumper with the captured nuts. We cut length wise under the three captured nuts and didn't cut the frame at all.
The bumper bolts to the bracket and sits on top of the frame. I think I'm gonna make up a bracket to run from the spot on the frame where the 3rd stock mounting hole is, up above the top of the frame and bolt through it into the 3rd captured nut. Maybe even weld along the seam between the bumper "tab" and the frame on each side, I haven't decided yet.
SmokeyMcBlazer
by v7guy » Mon Dec 29, 2014 7:58 pm
What Dennis describes is how you're suppose to go about it. We had the same issues when I installed the first body lift. Sounds like you got it figured out though.
by SmokeyMcBlazer » Mon Dec 29, 2014 8:08 pm
Cool, I think what we did should be ok. I do tow with the truck so, I probably will have it weld it a little. Everything seemed to go pretty smooth except that one of the captured nuts for the second to rear drivers side body mount spun freely. We had to pull some carpet and cut a hole into the floor above it. The hole was small and the channel runs below it so I don't think it'll cause me any grief. Its not open to the elements or anything.
SmokeyMcBlazer
by Opeth » Mon Dec 29, 2014 11:40 pm
Look in my build thread, I've got some pics of those brackets half installed and how much of the frame needed to be notched.
by v7guy » Tue Dec 30, 2014 2:15 am
You should not tow with those brackets/body lift. It's not anywhere close to as strong as stock.
by SmokeyMcBlazer » Tue Dec 30, 2014 6:56 am
so, nobody with a body lift tows anything? wish I had known that before hand...
I'm gonna go to a welding shop and have everything back there welded into a solid chunk of metal. The truck has to tow or its useless to me...
SmokeyMcBlazer
by v7guy » Tue Dec 30, 2014 8:32 am
Since you didn't cut the frame it should be a lot stronger than if you did. If the only thing you cut is shown in the pic I'd say your probably good to go. Might want to add the lip back in if your able.
Guys tow with the bracket. But when you think about the thin (now unboxed) metal of the frame rail supporting the bumper I'm sure you can understand why it's a horrible idea.
After you notch the frame it's kind of equivalent to welding a piece of 1/8" thick L channel to the frame then bolting a hitch on to that and towing with it.
by Grimor » Tue Dec 30, 2014 9:32 am
I've towed with my lift and haven't had a problem. no deflection on the receiver, no noticeable flex either. and this is with a 12" drop pulling a 8x18 loaded trailer.
Grimor
by SmokeyMcBlazer » Tue Dec 30, 2014 10:51 am
Yeah Jason, the only cut was the one shown. Instead of cutting the bumper support down and notching the frame up to the spare tire cross member, we cut the bottom lip from the bumper support horizontally (as it sits when installed). Now the bumper supports sit ontop of the frame but run all the way back to their original position.
I think I'll have the bumper supports welded to the frame rail along the edge that we cut off. That way the bumper is permanently attached to the truck. If I ever get a custom bumper for the rear, I'll just have the current bumper chopped back off.
Oh... and thanks for the personal experience regarding towing Dennis!
SmokeyMcBlazer
by Opeth » Tue Dec 30, 2014 11:53 am
I tow my 3500lb boat with them, however I will say don't tow through a tire carrier extension. There is too much slop in the holes and my brackets dipped down a few degrees and the steel bumper was actually pushing out on the bumper cover. I tried to use larger bolts but the frame holes are too small and my drill wouldn't accept the correct bit into the chock. The lower two bolts which go through the frame weren't the ones pivoting but it was the two which connect the bumper to the bracket.
If you weld both the brackets to the frame and run a weld bead on the steel bumper to the bracket you should be more than good. I think you should have mocked the brackets and bumper up first before you welded the brackets, mine don't sit level when my bumper does.
by HARDTRAILZ » Fri Jan 02, 2015 12:55 pm
I never had any issue towing anything with my body lift and rear bumper brackets.
by v7guy » Fri Jan 02, 2015 3:24 pm
Must be just fine then! I stand corrected.
Tow on guys! :thumleft:
by HARDTRAILZ » Fri Jan 02, 2015 3:27 pm
Its worth watching, but several body lifts in use and no reported issues.
by SmokeyMcBlazer » Fri Jan 02, 2015 3:32 pm
Cool guys, thanks for the update. I'm still gonna get some welding done back there just for piece of mind if nothing else. I paid a lot for my atv, don't want to leave it on the highway lol.
SmokeyMcBlazer
by ErikSS » Fri Jan 02, 2015 5:15 pm
Kyle, do you have the new or old style brackets?
by HARDTRAILZ » Fri Jan 02, 2015 6:57 pm
None now. I think I had both. I proto typed a solid dozen sets of the original when the first 3 inchers were being developed. I had a different set later down road when high voltage took over the body lifts to save them.
Regulator has my rear bumper and brackets currently. Unless he left it w Barton when they worked on his rear adaptation.
by Regulator1175 » Tue Jan 06, 2015 1:12 am
