by NC_IslandRunner » Thu Apr 24, 2014 4:33 pm
Got it back today! Transmission is running nice, PS pump replaced and a new AC Delco battery just installed.
by Trail X » Thu Apr 24, 2014 4:38 pm
Cable810 wrote:I found out that I have NO Bearings where the CV Shaft goes.....
That sounds about par for the course. Maybe a bit worse than most. That's why you've gotta check the play there, and check it often.
by Cable810 » Thu Apr 24, 2014 4:49 pm
The seals were pretty much worn out, the rubber was starting to crack as well...
by Cable810 » Thu Apr 24, 2014 9:00 pm
Ordered a new Fork, Thrust Washer, and Spring.... just going to add the awd sleeve when It comes in.
by trailboycer72 » Fri Apr 25, 2014 3:59 pm
Took advantage of a dry day and blacked out the grill and the wheels with VHT high temperature wheel paint. Recruited my oldest son to do some taping off. I like it and he seemed eager to help. And although it's not the official logo I made a temporary handcut decal for my Judith. ImageImageImage
trailboycer72
by Moots1288 » Fri May 02, 2014 9:52 pm
Found a leak on a seam on the firewall used some seam sealer, lets see how it works out
Finally got some motivation and installed the wiring for the arb compressor
by Cable810 » Fri May 09, 2014 11:08 am
Finally getting busy with this.
by Cable810 » Fri May 09, 2014 12:35 pm
Got the disco in.
by DirtyBacon04 » Sun May 11, 2014 4:06 pm
Installed the swingarm bumper/tirecarrier/thingamijigger (believe thats the technical term) from MDB. Pretty sure I'm using the other space correctly...
Mike had installed the brackets for these simple wire shelves, so I bought the arms and a 6 ft shelf, cut it to 4.5 ft. Also mike had spots on the carrrier for a highlift, but my highlift is already mounted so I got creative and used that spot for my shelf.
by dvanbramer88 » Sun May 11, 2014 4:14 pm
Miller lite :puker:
by mikekey » Sun May 11, 2014 4:27 pm
I like your El Camino
by DirtyBacon04 » Sun May 11, 2014 4:32 pm
dvanbramer88 wrote:Miller lite :puker:
I agree... I didn't have a case of my beer, so I had to improvise using my parents beer. lol
mikekey wrote:I like your El Camino
Thanks. It's actually my brother's car (user: PNutty) But he's stationed in CA, within a winches length of Roadie.
by Wahugg » Sun May 11, 2014 9:41 pm
My Z71 springs have sagged to some degree this past week hauling items around on the farm. To combat this until my air bags arrive, I put in some spacers and longer shocks. However I found the bushings to be the incorrect size. The bolt had WAY too much wiggle room and I figured it would wear the bolt and make a clunk every time the suspension changed direction of travel.
To combat this I found a steel bushing in our supply rack that was as close to the right size as possible, cut it in half with a cutting wheel, and inserted it in the bushing to fill the void. Worked perfectly!
-Wahugg
Wahugg
by dvanbramer88 » Tue May 13, 2014 7:43 pm
Ordered some parts to put a new fuel filter and fuel pressure regulator in my truck. Pulled the PCM and put it in a box. Sent PCMforless some money. Filled out an order sheet.
Can't wait for parts to arrive and my pcm to come back.
by Cable810 » Thu May 15, 2014 4:37 pm
Inspected the driveshaft ujoints and found a needle bearing in one of the caps. Might be the culprit of my mysterious popping noise. So I oderes a couple.
by mikekey » Sat May 17, 2014 4:49 pm
Well, the starter went out today. Since I don't feel like replacing it today, looks like next weekends project is to replace the starter.
by Mirage » Sat May 17, 2014 5:51 pm
Installed my James downing styled light bar. I used 3/8x2" carriage bolts with the head licked in the roof rack channel. That sucker not going anywhere.
Mirage
by DirtyBacon04 » Sun May 18, 2014 2:07 am
It's amazing how that simple of an addition seems to completely change the image of these trucks. I'm ashamed that I haven't built one yet
by KE7WOX » Sun May 18, 2014 1:39 pm
mikekey wrote:Well, the starter went out today. Since I don't feel like replacing it today, looks like next weekends project is to replace the starter.
Just out of curiosity, before it failed, did it seem to be getting stuck? My dad said his 05 EXT 5.3 has been doing that sporadically, and he thinks it's the starter.
KE7WOX
by mikekey » Sun May 18, 2014 1:46 pm
Nope, but my battery was drained and I was jumping it.
