Lets hear those opinions!!
dvanbramer88 wrote:Nice welds.
The oil pan skid looks like a tank.
The Rad skid is as good as you can get without the support bars or tying into the rad mounts like MDB designed. Your design doesn't look like the strongest thing out there, but it is certainly much better than nothing. It should do it's job just fine.
What thickness/guage steel did you use?
JamesDowning wrote:Not bad. If you really want to strengthen up that radiator skid, I'd suggest cutting 3 triangular ribs to run front-to back across under the existing skid. Make them reach as far back to the oil plate as possible. Then plate on top of it, in a diagonal slope connecting the front lip with the oil pan connector. That should provide some good rigidity against most anything you may throw at it. Only worry then would be the small cantilever out from the oil pan frame area.
