Gordinho's Rear Bumper Project
by Gordinho80 » Mon Jul 25, 2011 10:57 am
So I want to post up and get some feedback on my bumper plans...
I wanted to do something rather simple.... so I figured a good starting point is some C-channel. I put together this quick Google Sketch... its not to spec, was just done to be a 3D guide and reference point.
I started the project with 3/8" angle for mounting legs. I planned on running them through the channel so I can use them as shackle mounts. I will beef up the inside as well as add some flat stock outside to widen the mounts enough for 3/4 shackles.
Then my neighbor came through with a 10' section of 8" C. Starting with the whole piece centered to the vehicle. Cut through for the legs. Going to cut off either side right where I will make the first bend, just outside of the legs to follow the TB's lines closely. Will then notch the top and bottom of the C so I can weld the pieces on an angle. I will also cut the bottom lip of the channel off and will notch each piece to taper up 3". This will allow me to raise the sides 3" to fill in the gaps at the quarter panels. I plan on using flat stock to fill in gap under the taillights.
I've since picked up the hardware for the legs, (4) 9/16" Grade 8 bolts per leg, utilizing the 3 factory holes per leg plus a 4th on the bottom, like JD did. Also picked up a 2" receiver and cut the channel for that as well. The receiver sits inline with the bottom of the angle legs and will be reinforced internally with more angle and flat stock, connecting it to the legs to disperse the load.
Things might be a little slow as I do not have a welder and am currently relying on my neighbor and my brother in law to do all my welding. They both lead busy lives and work many hours... so finding common time while its not 100+ degrees out is tricky.
by Gordinho80 » Mon Jul 25, 2011 12:06 pm
Going to go with this for the swing out and latch...
http://www.emsoffroad.com/store/index.p ... cts_id=180
by Trail X » Mon Jul 25, 2011 12:14 pm
I like it!
Just some things to think about... make sure you have room to mount your swing hinge in the base. Even with my 4" wide bumper, we had to mount the hinge only half-in the bumper in order to clear the tail lights.
If you raise your side skirts 3", will your body reservoirs be hanging down below the skirt? Mine do and I think we did less of a skirt raise than 3", but I don't remember.
I think your project is already going faster than mine did.
Oh, also, plan ahead for the swingarm latch... they are a bit tricky to get right sometimes. We had to play with mine a bunch before finding a configuration that worked.
by janesy86 » Mon Jul 25, 2011 1:20 pm
Cool! Decent progress so far! Can't wait to see how it turns out! :cheers:
by Gordinho80 » Mon Jul 25, 2011 2:24 pm
A couple more pics... hardware and the receiver sitting in it's cutout. Again, all waiting for welding.
by MrSmithsTB » Mon Jul 25, 2011 2:25 pm
Making one for me too? You are too kind! :raspberry:
Just a suggestion.... since it isn't going to be sealed like James', you may want to roll up that bottom edge. I.E., add a piece of metal angled upwards. It will help keep the bumper from distorting if you happen to have a run in with some hard earth...
by Gordinho80 » Mon Jul 25, 2011 2:27 pm
HA! Let me get this one finished first... then we'll talk.
by Trail X » Mon Jul 25, 2011 2:32 pm
I wouldn't use Grade 8 nuts. They are highly heat treated, and welding them will mess up the treatment and make them brittle in the heat affected areas.
by djthumper » Mon Jul 25, 2011 2:35 pm
Looks like a solid plan.
by SomeOffPave » Mon Jul 25, 2011 3:19 pm
Gordinho80 wrote:Image
Things might be a little slow as I do not have a welder and am currently relying on my neighbor and my brother in law to do all my welding. They both lead busy lives and work many hours... so finding common time is tricky.
In my mind I see you driving around town with a 10 ft. wide bumper until the neighbor has time to do the welding. :lol:
Let us know how parallel parking and backing into your garage goes.
SomeOffPave
by The Roadie » Mon Jul 25, 2011 7:38 pm
SomeOffPave wrote:In my mind I see you driving around town with a 10 ft. wide bumper ...
I have so wanted to have a 4' deployable extension on my rear bumper to remind folks trying to sleaze past me on the right when a lane drop happens, that they need to take a number, and the line begins BEHIND me. :finger:
by NC_IslandRunner » Mon Jul 25, 2011 7:42 pm
X's 2
by djthumper » Mon Jul 25, 2011 8:12 pm
Definitely!
by Blackout » Mon Jul 25, 2011 10:01 pm
:Iagree:
Blackout
by mikepeters1983 » Wed Jul 27, 2011 11:50 pm
How much and when are people going to start making them?
mikepeters1983
Vehicle: GMC Envoy XUV
DriveTrain: 2WD w/ G80
by navigator » Thu Jul 28, 2011 9:01 am
just curious why you didn't cut the steel in half and have 2 ~5ft pieces instead of 1 5ft piece and what will amount to 2 2.5 ft pieces left over?
by Gordinho80 » Thu Jul 28, 2011 9:08 am
The steel will be the entire bumper. I centered it so that I knew I would not run out of steel on either end. The angled rear facing pieces in the sketch are also the same C channel... as are the side pieces. Once I make the first cuts and add those pieces back on at their angle, you'll be able to see it better.
by navigator » Thu Jul 28, 2011 9:11 am
I'm with you now man.
by HARDTRAILZ » Thu Jul 28, 2011 6:44 pm
simple and functional. I dig it.
by Gordinho80 » Sat Aug 06, 2011 6:52 pm
Finally got some more work done to the bumper. Forgive the few messy welds, this was my second time using a welder. I'm getting better.
I've got the hitch mounted carrier on there just so that I have my spare. I will be doing a swing out carrier once the shape of the bumper is completed. I also shot it with a quick coat of spray paint in case we got some rain these next few days.
