Potential short-run fabrication of TB platform off-road item
by glfredrick » Fri Aug 06, 2010 11:49 am
I've been talking to my kiddo, and we're kicking around the concept of building some short-run TB specific off-road parts. Bumpers, sliders, simple lift blocks, rear control arms, etc.
We have a tubing bender, good welders, lots of other fabrication tools, and some experience building our own and tons of other vehicles. We can't provide factory-level stress analysis, etc., but we can provide some custom fab work that seems to be almost un-obtainable for this platform.
What do you guys think?
glfredrick
Contributing Author
by bartonmd » Fri Aug 06, 2010 11:52 am
I, for one, might have to hit you up for some sliders...
I do sheet metal (skids, bumpers, etc.), but don't have access to a tubing bender...
by Gordinho80 » Fri Aug 06, 2010 12:09 pm
Sliders? :excited:
by Trail X » Fri Aug 06, 2010 12:12 pm
You're about 4 months too late to make me a rear bumper!...
After this rear bumper's done... I don't foresee many fabrication projects coming from me!
by bartonmd » Fri Aug 06, 2010 12:35 pm
I sent you a PM about the sliders (there's no popup on this site. You have to notice it at the top of the page)
by Gordinho80 » Fri Aug 06, 2010 12:51 pm
User Control Panel > Board Preferences >
Notify me on new private messages: Yes No
Pop up window on new private message: Yes No
by bartonmd » Fri Aug 06, 2010 12:52 pm
There we go...
by fishsticks » Fri Aug 06, 2010 1:14 pm
glfredrick wrote:I've been talking to my kiddo, and we're kicking around the concept of building some short-run TB specific off-road parts. Bumpers, sliders, simple lift blocks, rear control arms, etc.
Personally, I'd love to have a front tube bumper. Nothing uber complicated, but maybe with a winch plate/box in the center.
by aaronrules » Fri Aug 06, 2010 1:23 pm
Maybe another option for a body lift? Spare tire carrier?
aaronrules
by glfredrick » Fri Aug 06, 2010 2:58 pm
Fun thing about having a tubing bender, Bend Tech Pro, and a plasma (plus all the other stuff) is that making stuff is sort of easy...
But, just so everyone knows, we're just sort of fishing out the idea right now. My kiddo needs to produce some at-home income and this might be a way to accomplish that, seeing as how we already have a bunch invested for our own use.
Here's a few screen shots of Bend Tech. It can figure out stuff pretty well, including cages -- in 3D... :coffee2:
glfredrick
Contributing Author
by Rob93 » Fri Aug 06, 2010 4:32 pm
Maybe some sort of push bar for the front? Sort of like the brush guards but without the headlight guards
Rob93
by Philberto » Fri Aug 06, 2010 6:37 pm
I'd love to see a tube bumper for the front too, complete with headlight guards and tabs for limb risers. It would need d-shackles and a hole in front of the pass frame rail for winch line to pass through (think mini-fairlead).
by Regulator1175 » Sun Aug 08, 2010 8:11 pm
I would be interested in a set of rock sliders.
by glfredrick » Sun Aug 08, 2010 8:15 pm
I'm passing all this interest to my kiddo and we'll be talking about what we can cook up in the next week or so.
Thanks for all the interest!
glfredrick
Contributing Author
by glfredrick » Mon Aug 09, 2010 10:37 am
We're talking right now... Have a couple of questions about the differences between 5.3 engine and front suspension versus 4.1 engine and front suspension.
Does the front axle shaft pass through the oil pan on the 5.3?
What sort of oil pan does the 2wd I-6 use?
Anyone know?
(We're looking at a turn-key bolt-on 3-link SAS setup! :excited: )
glfredrick
Contributing Author
by Trail X » Mon Aug 09, 2010 11:06 am
They all share the same front differential system. All bolt through the oil pan, V8 and V6. The 2WD has the same oil pan, sans the differential. The hole in the pan is sealed.
You can see here... solid cylinder:
With front end disconnect installed:
by HARDTRAILZ » Mon Aug 09, 2010 11:32 am
I got axles if you make a bolt on kit... I could even come down for an install some you could take pics to use to make directions.
by glfredrick » Mon Aug 09, 2010 1:08 pm
HARDTRAILZ wrote:I got axles if you make a bolt on kit... I could even come down for an install some you could take pics to use to make directions.
We probably need a test mule vehicle for the SAS. We're close enough so that you may want to come on down so we can brainstorm.
glfredrick
Contributing Author
by glfredrick » Mon Aug 09, 2010 1:09 pm
JamesDowning wrote:They all share the same front differential system. All bolt through the oil pan, V8 and V6. The 2WD has the same oil pan, sans the differential. The hole in the pan is sealed.
Any reason that the hole couldn't be moved lower or the diff hung lower than the oil pan to gain a decent amount of lift up front?
glfredrick
Contributing Author
by HARDTRAILZ » Mon Aug 09, 2010 1:13 pm
glfredrick wrote:Any reason that the hole couldn't be moved lower or the diff hung lower than the oil pan to gain a decent amount of lift up front?
Was reading about the 92ish 4runner 5.5 inch kit and thats a big part of what they did. Just lower diff and few other things to keep angles good and it semmed fairly easy. Would it hold up to larger tires and rough terrain though?
I will send you a PM about some brainstorming.
