My knockoff of JD's amazing tire carrier.
by HARDTRAILZ » Tue May 25, 2010 3:41 pm
JamesDowning wrote:I'd also say that it looks as if your tire will interfere with the extension on the way down. Doesn't look like it'd lay flat... the tire would rest on the hitch.
Yep it seems it will need to be higher or it may not lay down enough to open the rear door.
by janesy86 » Tue May 25, 2010 3:43 pm
You talkin the pass thru reciever (extension), that sticks out like a foot?? Or the end that goes into our stock reciever? Either way I'm looking for him to basically shorten the pass thru reciever (extention) which I'll only really be using for a shackle for the most part.
And I'd like for the end that bolts to the stock reciever of the truck to be drilled a lil closer so the carrier butts up against the rear a little tighter.
Trying not to make it confusing to read my decription..
JD as for laying down flat.. I'm not concerned wiht that. As long as I can get to the cargo area it'l be perfect. And less of an effort to push the tire back up. But also if he does shorten the extension it might clear it.
I guess we shall all see if I ever get this thing. Otherwise I'll just cut holes in my bumper and make a swinging carrier like I ssuggested to Hardtrailz.
by HARDTRAILZ » Tue May 25, 2010 4:03 pm
The pass through is gonna leave a very weak point to have a shackle mounted. Any side load and it will bend.
The big question is if you have any money tied up in it. If so, you need to get what you want.
by janesy86 » Tue May 25, 2010 4:09 pm
No money in it so far... but thats why I've been tryin to contact him so I can get the changes made.
But I also don't want to screw him on this either.. just wish he was in my area then I'd be able to go there and easily have him make me stuff and actually use my rig for mock up. Right now he has to use one that goes to his school, so its not as easy as it could be.
by OregTrailBlazin » Tue May 25, 2010 5:23 pm
I do like the idea of making the end a shackle mount only. Like HardTrailz said, if your hauling a trailer you can mount the spare to it. Making it a shackle only, would shorten it up allot, and get rid of all the problems.
Johnny Kurz
General Manager
541-474-2879
Wheeler's Off-Road Inc.
Our Vendor Section
OregTrailBlazin
by janesy86 » Tue May 25, 2010 5:44 pm
Exactly... thats what I've been waiting on Neil to get back to me on. Other than that I like it so far and should be a nice piece...
by fishsticks » Tue May 25, 2010 10:25 pm
The hitch extension length was a big issue for me as well. One way I took some length off of mine was to redrill the pin hole on the male part of the extension. This got me a good 1.5-2" shorter overall. I may cut the female part down as well since my plan is to stick a shackle mount in mine too. On the other side of the coin, I'd like to keep the length along with a shackle mount as it would allow me to use the shackle as a HiLift jack point without removing my spare.
Since Neil has already made your tire carrier jog inwards a bit, you may not have the redrill option. Also, is being able to open your glass with the carrier up a concern for you? It looks like you may have issues depending on the angle he mounts the lug plate at.
On the plus side, I've used my carrier for recovery purposes already (with a 2" strap and a 5/8" pin through the hole in the extension) and it's worked well, even with a bit of sideloading. No deformation.
by fishsticks » Tue May 25, 2010 10:32 pm
madmanvillain wrote:im fabbing a tire carrier up this weekend tired of it taking up space and moving around in the back of my tb... cannibalizing a bike rack i made a few years back to make it...dont think ill get to making it fold down this weekend though, more important things to do like fixing my front end :mechanic:
The folding mechanism added maybe an hour to the design/fab process. Just look at how JD's/my/janesy86's hinges work. It's well worth it. My first try at this was a fixed carrier that slid in and out of the receiver to allow access to the liftgate. I HATED it.
by janesy86 » Wed May 26, 2010 6:37 am
For me I'm not concerned with the window... Only open the hatch for work to put in 5 gal buckets full of stone/sand so the window wouldn't cut it. So as long as it doesn't getin my way too bad to the rear I'll be fine.
by HARDTRAILZ » Wed May 26, 2010 8:17 am
[quote="fishsticks The folding mechanism added maybe an hour to the design/fab process. Just look at how JD's/my/janesy86's hinges work. It's well worth it. My first try at this was a fixed carrier that slid in and out of the receiver to allow access to the liftgate. I HATED it.[/quote]
:Iagree: I have a fixed one and it is not worth using. I figured....no big deal, but even though the window would open, not having gate access sucked.
by madmanvillain » Mon May 31, 2010 10:34 pm
made the rack...photos tomorrow so you dont yell at me...but i made it...for now it sticks out too far and doesnt hinge but i can open my lift gate with it on...ill end up bringing it in a bit and putting the pivot on it sometime soon.
madmanvillain
by fishsticks » Mon May 31, 2010 11:04 pm
madmanvillain wrote:dont yell at me
:hissyfit: :hissyfit: :hissyfit: :hissyfit: :hissyfit:
:need pics:
:cheers:
by djthumper » Mon May 31, 2010 11:06 pm
:Iagree:
by madmanvillain » Mon May 31, 2010 11:34 pm
:read: asshat.....
can i say asshat?? lol
madmanvillain
by madmanvillain » Mon May 31, 2010 11:36 pm
madmanvillain wrote:photos tomorrow so you dont yell at me...
madmanvillain
by fishsticks » Mon May 31, 2010 11:42 pm
madmanvillain wrote::read: asshat.....
I will take my asshat and wear it proudly! :chef:
Is it actually legal to pull a :read: on the OP of the thread? Hmm...
Mods! I need a ruling!
by madmanvillain » Mon May 31, 2010 11:50 pm
well if the OP cant read............lol
and i might say...your ass hat really brings out the brown in your eyes...
madmanvillain
by fishsticks » Tue Jun 01, 2010 12:00 am
madmanvillain wrote:and i might say...your ass hat really brings out the brown in your eyes...
My eyes are green. :coffee:
