Receiver-Mounted Tire/Fuel/Jack Swing-Out.
by bartonmd » Sun Mar 31, 2013 2:14 pm
He can buy this one this winter, after I build my rear bumper...
by bartonmd » Sun Mar 31, 2013 7:09 pm
Got the Trasharoo mounted.
Also, I'm thinking about doing something so that I can just let the swing go, and it won't break the gas spring. Debating about a limiting strap, or a mechanical means, somehow. Problem with mechanical means is the removal of the powdercoat where it would hit. I think I'll try the limiting strap, first.
Also, even though it doesn't rattle, when it's loaded and the swing is out, the hitch and system does flex an amount that means about 1/2 or 3/4" out at the bearing. I think I may do the strut on the passenger side, to the frame rail.
by v7guy » Mon Apr 01, 2013 1:10 am
Looks nice Mike, I dig it. :thumleft:
by Trail X » Mon Apr 01, 2013 9:31 am
Limiting strap... I like it! I need to do that. My cylinder has been de-threaded by a few accidents... so for now I just gorilla glue it every time it breaks. A limiting strap - now that's using your noggin! I'll have to steal that one eventually Mike.
by bartonmd » Mon Apr 01, 2013 9:43 am
JamesDowning wrote:Limiting strap... I like it! I need to do that. My cylinder has been de-threaded by a few accidents... so for now I just gorilla glue it every time it breaks. A limiting strap - now that's using your noggin! I'll have to steal that one eventually Mike.
Yeah, I don't know that I'd worry about it for me, but the wife will use this as much as I will, so it really needs to be "non-mechanically-savy-resistant". ETA: And I specifically don't want her letting it go, the cylinder breaking, and then the swing smacking the car next to her.
by bartonmd » Tue Apr 02, 2013 7:55 am
It went to Powdercoat this morning. I did end up putting the frame ties under it, because I didn't like the flex. It's 2 pieces. The pieces that are attached to the tube just go under the bumper and stop. The other pieces mount to the rear (2) hitch/bumper bolts on each side, and come down and bolt to the pieces that are welded to the tubes. We'll see how it shakes out, as far as how much better it is, but it won't be worse.
by Trail X » Tue Apr 02, 2013 12:43 pm
Looking forward to seeing it at TECORE.
by bartonmd » Thu Apr 04, 2013 9:12 pm
by Cable810 » Thu Apr 04, 2013 9:40 pm
Looks Realy Good Mike!!!
by Trail X » Thu Apr 04, 2013 11:25 pm
Very nice, Mike. The frame supports will also serve as nice skid elements, when needed.
by jonbo2002 » Fri Apr 05, 2013 7:43 am
OMG Mike that looks great. I would love something like that! well done
jonbo2002
by bartonmd » Fri Apr 05, 2013 9:55 am
Thanks, guys!
Got a pic this morning at work, with the trasharoo on it.
\Image
by mikekey » Fri Apr 05, 2013 11:29 pm
Geez dude, that is F*ing awesome.
by VelociJuris » Sat Apr 06, 2013 5:17 pm
Nice Work!
VelociJuris
by DustinC1989 » Sat Apr 06, 2013 7:27 pm
Nice, I wouldn't mind something like that instead of a full bumper
DustinC1989
by bartonmd » Sat Apr 06, 2013 10:23 pm
Thanks, guys!
The extra weight hanging back there did give me some lift on the front end, so I ended up putting in another 1" of spacer on top of Mark's 2" rear spacer.
by HARDTRAILZ » Sun Apr 07, 2013 2:13 pm
Sweet action!
by fishsticks » Sun Apr 07, 2013 5:34 pm
Totally going to build something like that... for my Runner. :finger:
Idea piracy FTW.
by bartonmd » Sun Apr 07, 2013 8:02 pm
Finally got all of the odds and ends nailed down.
Delrin block to support weight while it's closed.
License plate light and wiring.
by bartonmd » Wed Apr 10, 2013 9:50 pm
Boom! Lightweight, removable table!
