galacticfuzz wrote:Agreed Chris, looks are good, functionality are key. As for mounting the lights on the horizontal bar and tubing. The mounting bolt which hooks into the light is too short to mount to the bar with the adjustment blocks that sit behind the light and lock it in place. I had looked at doing that first with the bar I have and decided to upgrade in a way.
galacticfuzz wrote:. The other concern that I have is the mounting set up. Currently it's only one bolt on either side, but with the weight of it I may have to add an additional piece in front or behind to help the stress at the mountings.
.Regulator1175 wrote:Extend the stabilizer bar that you have on the mounting tabs all the way out to the side. This will provide another mounting point as well as help in stabilizing the lights themselves and preventing vibration.
navigator wrote:Regulator1175 wrote:Extend the stabilizer bar that you have on the mounting tabs all the way out to the side. This will provide another mounting point as well as help in stabilizing the lights themselves and preventing vibration.
I would think that would make it rock solid!
). So for now they ride in the back of the Trailblazer.galacticfuzz wrote:
Well, things didn't go exactly as planned.
You never heard of Murphy's Law before this project?
Apparently when I did the welding, the tubing warped slightly, causing the mounting holes to be off about 1/8th of an inch on the inside, to where I can't get the mounting bolts even into the tracks .
