I started out with a piece of 3/16" plate. Cut a couple brackets, drilled some holes with a hand drill and made sure they lined up on the truck then welded them to a flat piece that will cover the bottom of the radiator. I didn't have a piece quite long enough so the bracket got tacked to the end.
later I took some scrap and filled in the extra space. I'm pretty much at the limit of my welder with my current skill at 3/16" plate. I really have to spend time getting heat into the joint to get a good weld, consequently my welds are a bit higher than I'd like. I've cut across and it appears I have good penetration and beating a piece I welded together with a sledge hammer while clamped in the vise leads to it deforming without breaking. I've also resorted to a pretty heavy bevel.
Next I started laying out the span between the oil pan skid and the radiator cover part.
This is when I realized I wasn't going to have enough room on the piece for the corners so I cut some triangles, beveled the edges to make it easier to weld and clamped em down.
I figured it might be easier to take my 4.5" grinder with a cut off wheel and score the areas that needed to fold so that I could fold them over with a hammer as opposed to fully welding it. It seemed to work out alright. I just had to measure the angle from the radiator cover part to the oil pan skid on the vehicle and duplicate it in the garage when I was folding it.
Then I stitched the seam to make sure it staid put while I was test fitting that piece over and over and over
After that I cut out the piece that will cover the transmission cooler. I've found that scoring the metal with the cutoff wheel and then using the channel to hold cutting oil works well to keep the jig saw blade in good shape. I started using the jig saw for no other reason than to cut down on the massive mess the cutoff wheel makes.
I laid out the lines where I'll score the piece with the 4.5" grinder and started use my punch to mark where the holes for airflow will go.
The first couple holes I did with my hand drill, but it was wearing me out. So I assembled a drill press I was working on to start drilling the holes. It's still taking a tremendous amount of time.
This is about where I'm at now, I'm hoping to finish up tomorrow. Just gotta add reinforcement on the open span at the outside edge and finish up this front mount.
looks good!
