offroadTB.com • View topic - New from VA quick question as well
by jmar07 » Wed Feb 25, 2015 11:28 pm
Hey everyones name is jared I'm 26 from Newport News va. I drive a 04 trailblazer ext. I have the 3 inch suspension lift and just got marks adapters. My dads 96 Chevy 1500 got totaled but had brand new tires on it. The wheels are 16 though anyway I bought the adapters. The rears fit just fine the fronts are hitting the calipers. From what I've read I can switch the calipers to the non ext calipers and the wheels will fit. I have to get these tires on mine r shot to the cords. I'm wondering can I grind the calipers that r on there now down to where the wheels will fit just until I get my new calipers. I really need to get these on there or I will have no vehicle. Any help is greatly appreciated. Thanks
jmar07
by TBYODA » Thu Feb 26, 2015 1:58 am
Calipers are the same between the SWB & EXT. What is different is the size of the rotor. SWB rotor is 12.4" and EXT/SS/5.3L SWB is 13". So you don't need new caplipers. Rev. viewtopic.php?t=4622
by jmar07 » Thu Feb 26, 2015 11:31 am
Thanks for you're help. That's the thread I kept reading last night and was just confused probably cause I was so mad from working on truck. So if I put a regular trailblazers rotor and caliper mounting bracket on my truck the 16 wheels will fit
jmar07
by HARDTRAILZ » Thu Feb 26, 2015 11:35 am
The difference is not only the size of the rotors but the brackets that hold the caliper as well.
You could do the smaller rotors and brackets and make it work with less braking ability.
by jmar07 » Thu Feb 26, 2015 11:37 am
Ok great will my ext caliper bolt right up the smaller bracket of a normal tb
jmar07
by jmar07 » Thu Feb 26, 2015 11:38 am
And let me just say yall are awesome. I was so mad last night and I got online to start looking this stuff up and saw this page and was like hell yeah I have to join this
jmar07
by HARDTRAILZ » Thu Feb 26, 2015 11:46 am
When I did the swap from small diameter rotors to the larger I reused the caliper in the EXT brackets, so I would assume so....but I do not know of anyone going the reverse as you plan to know for sure.
by jmar07 » Thu Feb 26, 2015 11:54 am
That's what I. Curious about cause the smaller rotor makes sense but in order to move the caliper in I would need the other bracket and I'm curious if it bolts right up seems like it would be different. Is grinding the calipers safe or no
jmar07
by HARDTRAILZ » Thu Feb 26, 2015 11:58 am
Depends on amount to grind. I have done with success on vehicles, but some swear you will kill a busload of nuns if you do such actions.
by v7guy » Thu Feb 26, 2015 12:06 pm
The caliper bracket mount on the spindle is the same. You only have to get the caliper mount bracket and the smaller rotor and bolt it on. If I remember correctly the SWB trucks have aluminum calipers and the EXT/V8 etc have iron. So while it's a different material it's dimensionaly the same.
by jmar07 » Thu Feb 26, 2015 1:06 pm
Ok so I'll buy the caliper mount bracket and rotor for a normal tb and that should allow them to fit. The grinding I feel like would work and still be ok but when I look around online people r saying only idiots would do it and you will kill people and all that so it does scare me lol
jmar07
by jmar07 » Thu Feb 26, 2015 1:48 pm
Just took my calipers(measuring calipers not brake) and measured the brake caliper compared to one I haven't ground at all I've only removed .020 there's no way that will cause failure
jmar07
by jmar07 » Sat Feb 28, 2015 9:16 pm
Hey everyone!!!! Quick update here. Got the 33s on!!!! Went to pick n pull today and took the entire front brake setup off an 06 envoy. Got all that put on and my wheels fit perfectly. I will try to get some pictures up as soon as possible. Thanks for all the advice everyone couldn't of done it without yall!!
jmar07
by TBYODA » Sat Feb 28, 2015 10:27 pm
Good deal, Jmar.
