offroadTB.com • View topic - New Trailblazer owner from Utah
by jstreet » Thu Jun 12, 2014 5:21 pm
I've been lurking for a couple of weeks and have been getting great info on my new Trailblazer so I thought I'd finally register, introduce myself and say thanks for all the great instructions! The wife and I just picked up an 04 TB LT EXT with the 5.3 a couple of weeks ago since our growing family needed a little more space than the 05 Subaru Legacy was giving us. I paid a few hundred over dealer trade in value for it since it had a couple of minor issues.
It has 124K miles and has had regular fluid changes but no major maintenance besides the rack and pinion that was replaced around 10k miles ago. The immediate problem is the front end is shot, it needs all new ball joints plus an upper control arm, outer tie rod and hub wheel bearing that is starting to go. The truck had newer tires on it with only 5k miles on them but the front tires were already worn down to the threads due to the front end. The shop wanted $1500 just for the ball joints and one control arm so I'm doing the work myself this weekend. I'm replacing both upper and lower control arms (raybestos professional), ball joints (raybestos professional), both outer tie rods (AC Delco) and both hub bearings (Timkin) plus installing some new Bilstiens and stabilizer links/bushings (Moog) all around. I know some of the parts aren't broke yet but I figure why not since I'm going to be tearing everything apart anyway. I don't mind wrenching but their are definitely other things I would rather do with my time. I'm hoping to get it all done in a long day(minus the rear shocks) and it seems doable with the right tools, which I have. :D
I'm not a mechanic and have never done a project this big on my own before, so wish me luck! I'm very mechanically inclined and I've read several threads, watched a few videos on each part I'm replacing plus I've read the factory service manual front suspension section a few times. I also created a checklist from the service manual so I do everything in the right order and don't forget something. I feel I'm pretty prepared for the job but you never know.
Anyway thanks again for all the great knowledge!
jstreet
by mikekey » Thu Jun 12, 2014 5:30 pm
Welcome to the site, you've just joined an awesome family.
by DirtyBacon04 » Thu Jun 12, 2014 6:50 pm
Oh, yea. what he said. And you're livin in Utah... that is the offroad Mecca
lucky bastard
by jstreet » Thu Jun 12, 2014 7:07 pm
jstreet
by Diacom » Thu Jun 12, 2014 9:06 pm
Welcome, check out the trip section here on the forums, you'll be in for some company in a few months.
by TBYODA » Thu Jun 12, 2014 9:14 pm
Welcome, if you have no history on the fluid changes for the transfer case I'd change with autotrack II. Has 50k interval.
by jstreet » Thu Jun 12, 2014 9:57 pm
jstreet
by Cable810 » Thu Jun 12, 2014 10:29 pm
Welcome!!!
by DirtyBacon04 » Fri Jun 13, 2014 3:56 am
by mikekey » Fri Jun 13, 2014 6:14 am
I agree with the above. Also, to add to the Jiffy lube thing, a lot of the oil change places hire people with the same level of experience as a cashier working at walmart. Some of them usually have a head mechanic who is ASE and then they slap that on the building, to falsely make you assume all their mechanics are ASE. Changing oil isn't a super difficult task, paying for a building and paying workers and charging $35.00 for an oil change, you have to stop and wonder where they are cutting corners to make profit. It starts to become obvious if you go into one, look around and start to think about it.
by navigator » Fri Jun 13, 2014 8:01 am
I didn't notice in your opening thread any mention of a lift.
While you have the front end apart would be the perfect time then you only have to compress your front springs once.
by NC_IslandRunner » Fri Jun 13, 2014 8:59 am
Welcome! I could bash quick lube places all day, but I'll leave that for another day.
by navigator » Fri Jun 13, 2014 9:35 am
yeah, I would rather change my own than wait for someone else to do it. You also get the peace of mind having been under there and noticing any new leaks/issues.
by jstreet » Fri Jun 13, 2014 10:57 am
jstreet
by v7guy » Sat Jun 14, 2014 12:16 pm
If you're not intending on lifting, gmtnation is probably a much better fit for you. We definitely skew our suggestions with a priority towards offroading and there is a much larger base of info for general trailblazer/envoy tech at gmtnation.
by chevycrew » Thu Jun 19, 2014 4:13 pm
Welcome... if you decide to get crazy... come check out mine...
