Howdy
by blown4pt3 » Tue Jan 03, 2012 1:03 am
from SW Michigan. Been over to this site many times over the last year or two. Figured I should join at least. My purpose is probably a bit different than most on this site though. Many of you are into increasing the "Sport" part of SUV, while I'm needing to increase the "Utility". In practice, its not really that much different. Instead of climbing over a log in the trail, I want to recover it and use it for fuel (as in burning it for heat). So I do need to increase the offroad capability, but don't need things like a body lift, all while not trying to reduce in town gas mileage to single digits.
blown4pt3
by The Roadie » Tue Jan 03, 2012 1:07 am
Welcome! Your needs for recovery and emergency equipment will be identical, and you will definitely be looking for stiffer springs like the Z71s and perhaps even the Airlift1000 bags for adjustability. Lots of cargo weight is tough on shocks as well.
by djthumper » Tue Jan 03, 2012 3:00 am
Welcome
by NC_IslandRunner » Tue Jan 03, 2012 6:05 am
Go ahead and max it out suspension/body lift 35" MT's Armored to the hilt and you can go deeper to get more logs and still make it back!
O yeah - Welcome! :viking:
by blown4pt3 » Wed Jan 04, 2012 12:40 am
Thanks for the warm welcome. Will give a little more background, my tb now has 156k and is my DD. It also serves as minivan and pickup truck. My plans are the protection parts from Mike along with a bumper w/receiver. I also will be adding some weekend wheels/tires, like 265/70/16 guard dogs. At some point, I'd like to add a Warn Powerplant winch, although one from HF will probably happen first as it will be needed in spring. And thanks to Roadie, I'll be doing a 8.6 swap soon. Been lucky so far with the 8.0 non posi. The only thing that I'd to do is swap the 18 gallon tank for a 22. I've done searches, but haven't found anyone that's done this before. Or I wasn't searching the right words. Oh, and I've replaced T-stats, but am still fighting a low engine temp condition. Like 180 to 185 consistantly.
blown4pt3
by v7guy » Wed Jan 04, 2012 1:12 am
welcome aboard.
I've had issues in the past where I received a faulty new thermostat that caused all sorts of headaches. Just a thought
by blown4pt3 » Wed Jan 04, 2012 1:46 am
v7guy wrote:welcome aboard.
Pretty much what I'm figuring, although I don't want to admit it. The next one will be tested before installation. Running that cold sure isn't helping the winter time MPGs...
blown4pt3
by DirtyBacon04 » Wed Jan 04, 2012 9:31 am
Well not letting the oil heat up is causing premature wear on your engine rather than just your mpgs. Look into a block heater for the winter months.
by Mooseknuckle » Wed Feb 22, 2012 10:38 pm
Welcome
I don't dial 911
Mooseknuckle
