Hello everyone. I'm Rob and I live in the Columbus OH area. I want to first start off by saying thanks for a great site. Learned a bunch about my truck just looking around. I have a 03 Trailblazer 6 cyl 4WD short wheel base and open diff and 3.42 gears. I sold my 2000 Blazer ZR2 this past summer for the 03TB. The TB was such a good deal that I couldn't pass it up. Night and day difference on road manners and towing my Firebird to track days. The blazer just felt like it was designed in the 70's, oh wait it was... But off road, the Blazer in stock form is so much better than my TB. I've spent some time researching your posts and have found out what works and what doesn't and what I pretty much want to do to the TB. My goal is to make the TB at minimum, as capable as the Blazer ZR2.
Which leads me to a couple of questions I was hoping someone could help me out with.
Build plan:
31" or 32" tires
2" or 2.5" front lift
not sure on the rear lift yet
G80 or eaton LSD (forgot the name but torsion type) rear diff. I want a true locker but no plans to swap for a 8.6"
goodyear duratrac or general grabber AT2 tires
1) The tire size's I have settled on are 265/75 R16 or 265/70 R16 Basically 32" and 31" tires. From all of the posts the 265/70's probably will work on stock rims no spacer no lift and the 265/75 work with lift and wheel spacer.
I tow a car trailer 6-7 times a year about 5000 - 5500lbs. Any one tow around 5500lbs with 3.42 gears and 32" tires? Any issues? Is it a slug? over heat issues? trans hunting between gears to much?
will 32"s make the truck's transmission hunt between 3rd and 4th on the highway unloaded?
2) wheel spacers with the 32's Has anyone had any issues with them? From this site I've learn there are only two brands to consider. The Lift Meister or wheel adapter.com. I have not seen any one that had issues but wanted to ask in case I missed a post. I would prefer to get new wheels, but can't find any with 1-1.5" less back spacing.
Should I be concerned with wheel spacers, 32's and the extra load from towing a car?
3)Anyone solve the speedo error with tall tires? I saw a couple of posts but didn't see a solution. unless I passed over it.
Sorry for the long first post, I figured I'd list all the questions in one post instead of bothering everyone multiple times.
Thanks for your input.
