I do a lot of hauling (500+ lbs in the cargo area) weekly off road in the mountains and I tow a few times a year. This forum seemed to fit what I'm looking for.
I do have a question however (Yes I have been searching can't find it) Am I going to be ok running the bilstien HD TB shocks in the rear with the Z71 springs and a suspension lift? I got the 2.75" front and the .75" rear. Keep in mind I don't do rock crawling, I stick to the easier trails and rough dirt roads. I mainly was after more towing capacity than stock. But now I want some larger tires since I am lifting it but on stock 16" rims with no spacers. Am I going to have problems with the rear shocks or do I need to return the HDs when they arrive and get the BDS? Its a daily driver so I don't need super articulation, but I don't want it unsafe either.
ditch the bilsteins and go with BDS 5500 in the rear. You will thank yourself in the long run.
