Drivetrain Specs: 5.3L, 4WD, 3.42, G80
Suspension Modifications: 2" rear lift blocks, Bilstein 5125 33-185552 with 255/70 valving, and Airlift 1000 airbags, and front Radflo coilovers. Deleted rear sway bar, and front heim links.
Wheels / Tires: BF Goodrich All-Terrain T/A KO2, in LT265/70-17 Load Range E. Stock wheels with 1.5" hubcentric spacers/adapters.
Exterior Modifications:
- GM fiberglass fuel tank / T-case shield
- "Wife-Resistant Running Boards" for the wife (her DD)... 2" x 6" x 3/16" boxed sliders, mounted on 2" x 2" x 1/4" legs, that are welded to load spreading plates, welded to the frame. Recently added 2" to the rear for tire kick-out and more foot room.
- One each of my (MDB Fabrication LLC, AKA "MTA") bumpers, radiator skids, and oil pan skids:
viewforum.php?f=35"
- Got rid of the stock resonator, and welded in a stainless Magnaflow muffler
- Open, blacked out LT grille
Engine Modifications: 5.3L LH6 V8. Tuned with Magnaflow muffler and no resonator. Trans cooler with thermostatic bypass.
Interior Modifications: Hooked into rear seat cig. lighter wiring and added a 2-pin SAE connector to plug in inverter. This frees up the rear lighter port, is a more secure connection than a lighter port, and allows the use of said port while rear seats are down.
Rear cargo cage, made by me.
Recovery Equipment:
- 48" Hi-Lift jack - http://www.hi-lift.com/hi-lift-jacks/all-cast.html" onclick="window.open(this.href);return false;
- Off-Road Base - http://www.hi-lift.com/accessories/off-road-base.html" onclick="window.open(this.href);return false;
- Lift-Mate wheel lift hooks - http://www.hi-lift.com/accessories/lift-mate.html" onclick="window.open(this.href);return false;
- Off-Road Kit for Hi-Lift - http://www.hi-lift.com/accessories/off-road-kit.html" onclick="window.open(this.href);return false;
- Jack repair kit - http://www.hi-lift.com/accessories/fix-it-kit.html" onclick="window.open(this.href);return false;
- Smittybilt X20-10 winch with Spider-Silk winch line and a Factor55 Flat Link
- 20' of 3/8" Grade 70 transport chain
- 2" x 20' static "tow" strap
- 2" x 30' dynamic "extraction" strap
- 2" receiver shackle mount for rear and front (plus shackle mounts on bumper)
- A bunch of 3/4" shackle mounts
- 4' of 3/8" grade 70 transport chain with hooks on both ends (for wrapping around frames of vehicles without shackle points)
- Extra hitch pins
- 2 x 100' of synthetic winch line extension
Electrical Modifications:
- Driving lights - In the bumper, 55W LED "spot" beam lights. When they're turned on, they turn on and off with the HIGH beams.
- Light Bars - Also in the bumper, 19" single row and 21" single row, enabled by HIGH beams, but on a separate switch, so they don't have to turn on with the HIGH beams.
- Marine power-switch for winch power
- Cobra C75-WXST CB Radio, and associated antenna (seen below)
- Tekonsha P3 brake controller (install here: http://www.offroadtb.com/articles/how-t ... r-install/ )
- Ultragauge
