offroadTB.com • View topic - Need a new rear end
Need a new rear end
by Trailblazin02 » Wed Apr 01, 2015 8:52 am
So I'm pretty sure the rear end in my 02 tb is junk. She don't move and makes a bunch of grinding/ clunking sounds when it's in gear.
I plan on replacing it witha salvaged rear.
What's my best option when looking for a replacement?
Trailblazin02
by HARDTRAILZ » Wed Apr 01, 2015 9:03 am
Depends on your mission. What gearing do you have? Are you looking for something locking or planning to add a better aftermarket locker?
by Trailblazin02 » Wed Apr 01, 2015 9:26 am
I have the 3.73 gears. Idk. If I can find something that's locking it would be nice. I do some off-roading/ mudding when going hunting and fishing. I'm looking for a quick fairly easy fix for now
Trailblazin02
by HARDTRAILZ » Wed Apr 01, 2015 9:32 am
Where are you located?
Grab one from a junkyard and roll with it. Basic upgrade with a quickness and ease would be the 8.6 with G80 and your same 3.73.
by Trailblazin02 » Wed Apr 01, 2015 9:48 am
I'm in northern Illinois by Rockford.
I did a little quick search last night and kinda looked on ebay to see what was available. There's a ton of salvage yards around so I'll need to start calling. What you recommended is what I was leaning towards Just wasn't sure if I was on the right track or not
Trailblazin02
by Jrgunn5150 » Wed Apr 01, 2015 9:58 am
Are you using Car-part.com also? And, LKQ Will do a pull and send you anything you like.
by Trailblazin02 » Wed Apr 01, 2015 10:22 am
There is an LKQ in rockford so its not far away. I'm going to call some places today an see what I can dig up. Ill try the carpart site also
Trailblazin02
by Trailblazin02 » Wed Apr 01, 2015 10:37 am
Ok guys I found this one 45 miles away. They want $440 does that seem like a fair price? An this will bolt in to my 2002?
And have you heard anything about the Spohn performance rear upper and lower arms they sell?
Rear Axle
2007 Chevy TrailBlazer
3.73 RATIO,LOCKER,GT4,G80,2-07,4.2,A. T.,4WD,4W-ABS,4DR,LT,113WB
80,305 miles
Trailblazin02
by HARDTRAILZ » Wed Apr 01, 2015 10:50 am
That is the smaller 8.0 but a direct replacement.
You might want to get through the rearend discussion before mixing in the control arms or things get complicated. Maybe even a new thread or search and post about them in one of the existing control arm threads.
by Jrgunn5150 » Wed Apr 01, 2015 10:50 am
It will bolt in, but the wheel sensors are different on 06 and up. I'm not sure if you can swap sensors on the axles.
by HARDTRAILZ » Wed Apr 01, 2015 10:57 am
You can put any axle in the older trucks like his. You throw a code and lose stabilitrak trying to put a old axle in an 06 or newer. The info is mentioned plenty of times around the site.
by Trailblazin02 » Wed Apr 01, 2015 11:06 am
It sucks I'm on my phone at work trying to get this figured out. Otherwise I normally hit the forums pretty hard rather then just tell me what I need.
How would I search to find a 8.6" rear? We're those in the v8 models?
Trailblazin02
by HARDTRAILZ » Wed Apr 01, 2015 11:13 am
Short wheelbase V8 or any Long wheelbase
by Trailblazin02 » Wed Apr 01, 2015 11:18 am
Ok now I got it lol. Got way too many numbers In my head today lol.
I just did a quick search again. This place by me Is a trailvoy junk yard heaven by the looks of it
2007
Rear Axle
Saab 97x 3.73 RATIO,LOCKER,GT4,G86,9-06,5.3,A. T.,4WD,4W-ABS,4DR,ARC 65,067 miles
$330
Trailblazin02
by HARDTRAILZ » Wed Apr 01, 2015 11:28 am
G86 is the limited slip rear but should work well for what you described. Will bolt right in. Will have sensors toward the wheel ends of the axle tubes you do not need with your older model. Cut the wires and just leave the sensors to plug the holes.
by Jrgunn5150 » Wed Apr 01, 2015 11:39 am
If you found it on Car-Part, make sure you call, and stress that they absolutely have the part, I've been burned before.
by Trailblazin02 » Wed Apr 01, 2015 11:41 am
Yeah ill Def call. The actual place has quite a few listed on there actual site for all models i6 and the v8. So even if that exact one is gone there's more to be had
Trailblazin02
by Trailblazin02 » Wed Apr 01, 2015 12:04 pm
I did some more looking they have 2 listed with G80 and a bunch with the g86. And they're all around $330 which don't seem bad. They have 128k & 99k miles on the ones listed with g80.
Trailblazin02
by HARDTRAILZ » Wed Apr 01, 2015 12:07 pm
You will likely only ever notice a difference if you get one of the rear tires off the ground.
by djthumper » Wed Apr 01, 2015 12:12 pm
