offroadTB.com • View topic - Rear Axle Brake Shield Replacement
by Wahugg » Mon Mar 31, 2014 2:54 pm
The axle that I ended swapping into my TB about a month ago didn't really have brake shields. The left side was rotten and the right side was non existent. I figured to swap them to my new axle off my old axle during the swap, but I ran into a hiccup. I removed the wheels, brakes, half-shafts, and e-brake assembly (25) but the brake shield still stayed on. I pulled/ hammered as hard as I could (not much because the shield is so thin). Am I missing anything?
-Wahugg
Wahugg
by Moots1288 » Mon Mar 31, 2014 3:31 pm
You dont need those brake sheilds
by bgwolfpack » Mon Mar 31, 2014 3:37 pm
Did you remove bolts #26?
by v7guy » Mon Mar 31, 2014 3:39 pm
I find rust makes them shitty to get completely off. Assuming the bolts are out I'd break out the chisel
by Wahugg » Mon Mar 31, 2014 3:46 pm
Bolts 26 were removed in order to get the E-Brake Assembly number 25 (minus the brake shield)...
38, 36, 1, 27,28, 26, 25, were all removed.
-Wahugg
Wahugg
by dvanbramer88 » Mon Mar 31, 2014 3:49 pm
Those brake shields are great at collecting rocks and gravel that grind against the rotor and make terrible noises. I cut my front shields off. Also cut all 4 off of my dads truck. They're pointless really.
by Wahugg » Mon Mar 31, 2014 3:57 pm
I would be inclined to agree with you if they were purely disc brakes, but I am afraid that girt or gravel could get into the E-Brake Drum and chew up the shoe.
If they were there from the factory, they were probably there for a reason.
-Wahugg
Wahugg
by bgwolfpack » Mon Mar 31, 2014 4:23 pm
Those shields are mated with the backing plate, held on with bolts #26 and should come off.
I agree they should be there, (need) to be there.
I looked at Rockauto, but do not see them offered.
by Wahugg » Mon Mar 31, 2014 4:43 pm
I don't need new ones, I just need to get the good ones off my old axle and the rotten ones off the new axle.
Wahugg
Wahugg
by Aries » Mon Mar 31, 2014 7:45 pm
Aries
by Wahugg » Mon Mar 31, 2014 8:21 pm
Of the few DIY videos on youtube, that one is up there. Thanks :thumleft:
It appears that I just didn't hit it hard enough with all the rust build up over the years. I'll take a torch to it the next time I have a go at it and see if that helps to loosen it up at all.
-Wahugg
Wahugg
by Shdwdrgn » Fri Apr 04, 2014 5:54 pm
FYI you can get these off of Amazon -- Dorman 924-208 -- for $20/pair. When I replaced my rear axle, everyone told me to just leave off the dust shields, so I never replaced mine. So far no problems, but I've only been running without since September.
Shdwdrgn
Contributing Author
