New to gearing whats my options?
by HARDTRAILZ » Thu Aug 30, 2012 12:47 pm
Cable810 wrote:We swap the rear and have to do the front as well for the gears? Thats what I'm understandin.
Correct if you want to be able to use 4x4
by c bausch » Thu Aug 30, 2012 12:52 pm
So a gt5 rear from a ext ? Does year of the trucks matter?
c bausch
by djthumper » Thu Aug 30, 2012 12:57 pm
c bausch wrote:So a gt5 rear from a ext ? Does year of the trucks matter?
Yes the years matter. For anyone with a <2005 can go with any of the rear ends. Those of us with >2006, should have a 2006 or newer rear end to save a lot of other work.
by HARDTRAILZ » Thu Aug 30, 2012 1:00 pm
Which is why it was easier for me to find a stronger SS rear w 410s than an 06 or newer 8.6.
The older ones dont have the speed sensors on each side of rear for stabiltrak n abs.
by Infamouz » Thu Aug 30, 2012 1:33 pm
If I remember correctly even us 06-09 can use the 02-05 axle right? and all we would have to do is get a reflash on our pcm for the codes, right?
Infamouz
by HARDTRAILZ » Thu Aug 30, 2012 1:42 pm
What codes? You lose stabilitrak and abs.
by navigator » Thu Aug 30, 2012 1:49 pm
I think if you don't have the ABS sensors connected on the newer models it throws a code/ABS light.
by navigator » Thu Aug 30, 2012 1:50 pm
Kyle, on your SS rear, was it a direct bolt swap or did you have to do some mods to the driveshaft etc? I seem to recall you had to do a little more than a normal swap. Was that due to the different rear or to the amount of lift?
by HARDTRAILZ » Thu Aug 30, 2012 2:02 pm
I had to shorten the driveshaft even w my longer control arms.
by navigator » Thu Aug 30, 2012 2:15 pm
Was that due to the amount of lift or because the SS diff is longer?
by HARDTRAILZ » Thu Aug 30, 2012 2:29 pm
Diff is that much bigger.
by navigator » Thu Aug 30, 2012 2:44 pm
ok, good info.
by 06MidnightBlue » Thu Aug 30, 2012 4:33 pm
If you swap only the rear and don't re-gear the front, say goodbye to your transfer case and all associated parts.
06MidnightBlue
by c bausch » Thu Aug 30, 2012 6:52 pm
Will the front blow by itself ? Or when you engage the 4wd?
c bausch
by 06MidnightBlue » Thu Aug 30, 2012 7:05 pm
I can't tell you much about the mechanics of it. But what I can tell you is that a friend of mine did that in his 4Runner. The second he put it into drive, pop goes his front u-joints and something in his T-case snapped too.
Long story short: $2150 in repairs. He had to replace the T-case
06MidnightBlue
by HARDTRAILZ » Thu Aug 30, 2012 7:07 pm
I had front 373 and rear 410 for a few weeks. Even couple hundred highway miles. Its not a problem unless you engage 4x4.
by fishsticks » Thu Aug 30, 2012 8:34 pm
HARDTRAILZ wrote:I had front 373 and rear 410 for a few weeks. Even couple hundred highway miles. Its not a problem unless you engage 4x4.
x2
by c bausch » Thu Aug 30, 2012 8:52 pm
Hardtrails, what kind of rear did you have back then?
c bausch
by HARDTRAILZ » Thu Aug 30, 2012 8:58 pm
I had the 3.73 8.0 then went to 4.10 9.5.
by 06MidnightBlue » Fri Aug 31, 2012 11:39 am
If you look at the build thread for it though, it's quite a project.
06MidnightBlue
