Broken spider gears
by teebes » Tue Aug 31, 2010 8:08 pm
BTW... The shop I'm getting the work done had a customer leave a perfectly good G80 from a previous job. I might be able to pick it up for cheap in case anyone here is interested. Believe it will be for a 8.0, swb housing.
teebes
by Trail X » Tue Aug 31, 2010 10:09 pm
Awesome Greg. Fun how misfortune can turn into a good thing.
You've got OBA, are you going with an air locker?
by teebes » Tue Aug 31, 2010 10:47 pm
JamesDowning wrote:Awesome Greg. Fun how misfortune can turn into a good thing.
Leaning towards the Auburn at the moment. Usage is just as easy via the push of a button with less maintenance. This article seemed to sum up the pros and cons, but was published before the etched was mainstream: http://www.4wheeloffroad.com/howto/21459/index.html
Alekg's comments on the limited slip of the auburn is also a nice feature ( although even that may require wear on the clutch plates after long term usage, think g80 usage). Of course, engaging the locker when actually needed should greatly reduce that interval.
teebes
by Philberto » Wed Sep 01, 2010 3:05 pm
The Roadie wrote:It could have been Montrose, CO all over again if we had been on the trail and you had to limp off. You got AAA?
I will post Monday about my adventure after some dash-droid-cam videos upload.
Did you mod the car mount to allow the camera to work? Mine covers the lens.
by Zero » Sat Sep 04, 2010 10:28 am
Why would one choose an air locker over an electronic one? I know when my g80 fails I want to throw it away and get something like Aleks with a limited slip. His limited slip does an amazing job, ive seen it work.
