Hi I've been looking and looking at opinions of g80 swaps for my 2005 trailblazer ls; it has a 2 inch lift and has 31.5 inch tires on it. I know I have a 3.42 differential ratio and a 8.0" differential. I'm open to a axle swap if needed. I'm only 17 and on a tight budget, so i don't want to screw anything up, but i want to install g80 or some type of locker in my trailblazer. If i go from a 3.42 to a 3.73 what would i need to do? ive found two different opinions for axle swaps on ebay that im not sure about, looking for opinions, suggestions and tips.
3.42 ratio axle with g80- http://www.ebay.com/itm/REAR-AXLE-TRAIL ... d4&vxp=mtr
3.73 ratio axle with g80- http://www.ebay.com/itm/02-03-04-05-ENV ... 0e&vxp=mtr
But I'll add this. If you plan on going to bigger tires(33" and bigger) skip the 3.73 and go to 4.56 thats if you know how to/know someone who can regear. Otherwise I'd try to find a 4.10 front diff and rear axle if 33s are planned. Be prepared to shell some cash on the project. When I did mine it set me back $1,400 thats for front diff and rear axle.
