offroadTB.com • View topic - Ceiling Mount CB, Spectra Mount, and Rear Mount Antenna
by SaltWaterDrinker » Thu Feb 23, 2012 9:39 pm
Today Dave and I decided to get the Comm gear in the Trailblazer - I was missing it...haha. From the experience I had in my previous Trailblazer, having the CB mounted on the glovebox made it too far away to operate safely and way too hard to hear. I also learned that having the massive Laird Whip antenna mounted on the lip of my hood was a bit much, especially when running into low hanging tree branches with it during trail runs - it hurt when it whipped in my window! :?
I figured one night that all "business" comes from above...so I wanted to somehow mount my CB to the ceiling. The original plan was to mount it in/on the voice recorder and garage opener...but it was too honky and blocked the rear view mirror. Then, over the phone, it evolved into getting a small piece of metal and fixing it to one of the screws that hold the voice recorder/garage opener thing to the ceiling, allowing it to rotate so both driver and passenger could view the radio. However, that would require us to punch through the ceiling and...well, that was just a horrid idea. Then Dave figured we could remove the sun visor and mount it with the existing hardware somehow.
I wanted to use my existing Laird Whip, but mount it in the back of the TrailBlazer - kind of like what most of you guys have...just not punching through the side of the truck or using the "contact method." So, we figured we would mount it to the tail light or metal are above the tail light. It would keep it "lower" yet high enough so I could still get out to talk to my locals.
Somehow...my Midland 1000Z Blew up. When we hooked it up to test it, all you heard was a loud whining on the other end...no TX audio at all. So, since I had no other options, I put my 19DX in there which is over modulated since I broke the modulation adjuster on the board :facepalm: ; that's why you see two different radios down there:
Well, here are the photos - Captions are below the photos:
You can see here that we fed the Coax through rear of the tail light...
How the coax entered the interior...we fed it along the side.
Dave attempting to drill into the mounting area...with a wood bit...my fault; whoops. Bent bit below:
Close up of the Finished mount
Far off shot
INTERIOR
Where we brought the coax through
The CB - mounted where the visor used to clip into place
The really crappy sounding 19DX...
We fed the electrical across the top of the headliner, and down the driver side door area. We then fed it through the internal fuse box. I have a nasty alternator noise...I guess the 19DX isn't set to filter that out...or we did something wrong.
Finally...my not so complete VHF:
I got sick of the Johnson; the speaker was blown and it's receiver was dirt. So, I threw my trusty Spectra in there. We had to break the area in which we mounted it, but Dave put a screw into place to hold it - pretty clever. The only reason it is not complete is because I don't know how to wire it to the ignition - I'll make a Troubleshooting post on it soon. I plan to mount the VHF antenna to the opposite area above the tail light - It just seems more practical and allows me to pull this under the carport.
As time progressed...the camera became less and less of a priority and our patience began to become tested. Happy this is squared away now. I can't wait for the ribbing I'll get tomorrow when I jump in with the locals on 19.
:excited: :safari:
Cheers!!!
SaltWaterDrinker
by Bigbadbowtie088 » Thu Feb 23, 2012 10:26 pm
Very nice! I was fine tuning my CB today. Used my scanner to pick up the cb channel, was coming in nice and clear. I've got the cobra like you have pictured above. I think I finally got it squared away. I still need to install a new AUX cord to my PA speaker
Bigbadbowtie088
RIP
by Mooseknuckle » Fri Feb 24, 2012 6:18 am
Looks nice. Good job. I need to do something right now I have a magnet mount
I don't dial 911
Mooseknuckle
by SaltWaterDrinker » Fri Feb 24, 2012 6:59 am
Cheers!!!
SaltWaterDrinker
by bartonmd » Fri Feb 24, 2012 8:58 am
by dvanbramer88 » Fri Feb 24, 2012 9:02 am
by bartonmd » Fri Feb 24, 2012 9:04 am
by dvanbramer88 » Fri Feb 24, 2012 9:07 am
I just reached back there and put them on. It wasn't too hard. I held them with a socket while josh turned the screws.
by dvanbramer88 » Fri Feb 24, 2012 9:08 am
If you look in the very first picture, almost off frame to the left, next to the craftsman razor, those two screws/nuts are what we used.
by bartonmd » Fri Feb 24, 2012 9:22 am
Oh, I get it! You did it on the passenger side, and reached through the "storage comparment" hole, right? I did it on the driver's side, and there is no storage compartment hole, so there was nothing to reach through... I looked for like 1/2 hour for something to reach through, before I drilled that 7/8" hole...
by dvanbramer88 » Fri Feb 24, 2012 10:57 am
by SaltWaterDrinker » Fri Feb 24, 2012 2:02 pm
You ain't kidding, that was the worst part of it all. I was pleasantly surprised at how easy all of the panels came off...especially in the back cargo area. I envisioned having a repeat quality(poor) of what a professional radio shop did on my previous trailblazer...thankfully, this was not the case.
Cheers!!!
SaltWaterDrinker
by KE7WOX » Sun Feb 26, 2012 2:33 am
Nice install, a few questions.
- Did you put the mount on the bracket after running the coax? I have yet to see an NMO that can be mounted that way, all the ones I have seen you start by running the coax through the hole and then tighten it.
I am definitely thinking about getting one of those but with a whip that will do 27-30 so I can swap the CB for a 10m radio, given that I have no use for the CB except when traveling and maybe the PA speaker if I do go with one.
-What is the Spectra for? is it for VHF Ham?
by djthumper » Sun Feb 26, 2012 2:46 am
I have seen some that are generally used for a trunk lip mount but I have sen a few others.
He is using the spectra for MURS, though that is a bit overkill of a radio service limited to 2 watts. Which would mean the radio is either modded to go down to 2W or he is running it out side of the limits of the service.
by SaltWaterDrinker » Sun Feb 26, 2012 9:08 am
Cheers!!!
SaltWaterDrinker
by dvanbramer88 » Sun Feb 26, 2012 11:05 am
by SaltWaterDrinker » Sun Feb 26, 2012 11:11 am
Cheers!!!
SaltWaterDrinker
by KE7WOX » Sun Feb 26, 2012 12:46 pm
Yeah, my Icom puts out 65W I think. Almost nothing compared to the 110W Spectras. Was it too difficult to get it down from 146 to 144?
by SaltWaterDrinker » Sun Feb 26, 2012 12:49 pm
Cheers!!!
SaltWaterDrinker
by KE7WOX » Sun Feb 26, 2012 2:08 pm
Yeah, I believe the way to do it is to perform a HEX edit to certain values, then that switches everything, so if you put in a frequency that is within the range of the radio but shifted up from the real (eg. 152 on the software is 144 on the radio, 154 is 146 or something like that).
I have thought about picking up a couple of cheap Spectras to play with, as they're readily available in remote mount version, which is good with the TB, as it has like zero space to mount anything more than 1 radio within reach of the driver.
Return to Electrical / Radios
