AUX Imput on Stock Head Unit?
by SpecialEh » Sun Dec 26, 2010 11:16 pm
Sorry if i missed this in the search.
Does this head unit have an aux input in the back?
SpecialEh
by That1Guy » Sun Dec 26, 2010 11:47 pm
SpecialEh wrote:Sorry if i missed this in the search.
http://lmgtfy.com/?q=stock+trailblazer+ ... +aux+input
Previously known as NickNorie
That1Guy
DriveTrain: 2WD w/ G80
by djthumper » Mon Dec 27, 2010 5:56 am
That kind of stuff is best to be found on trailvoy.com
by cbbryan » Thu Dec 30, 2010 12:43 pm
Simple answer mine does, but it is Bose 6 disk changer. Just pull it out and check; it only takes 5 minutes.
cbbryan
by Hpimichael02 » Thu Dec 30, 2010 1:45 pm
only the bose versions have the out put, sadly most dont , chevy was behind the whole electronic movement... but from what i understand its only really meant for the dvd player package
Hpimichael02
by cbbryan » Thu Dec 30, 2010 2:27 pm
Output or input? You may be correct on the output, but I believe that you could hook up an iPod in the rear with the right adapter from peripheral I think is how you spell it. They made mine, and according to the geek squad guys at best buy if it says cd/aux you can do it.
cbbryan
by Hpimichael02 » Thu Dec 30, 2010 4:53 pm
HOW DOES THE RADIO COME OUT?
Hpimichael02
by SteveTB03 » Thu Dec 30, 2010 5:17 pm
You take off the front dash and you unscrew the radio... AND STOP THE DAMN YELLING.
Go Big & Go Broke
SteveTB03
by cbbryan » Thu Dec 30, 2010 5:30 pm
Hpimichael02 wrote:HOW DOES THE RADIO COME OUT?
1) procure Philips head screw driver, ratcheting screw driver, or drill (go with the drill it's quicker)
2) locate and remove 8-12 screws underneath dashboard (I never really counted them)
- this removes the bottom piece of plastic
3) next locate and remove the screws around the center head unit (if there are any) as well as unplug your heater controls and 12V outlets
- this removes the center head unit faceplate
4) now remove the screws holding the stereo in place, slide out radio, and unplug the connections (including the antenna) from the rear
5) finally now that the stereo has been disconnected you should be able to pull it on out
It's been a few months since I've don this, but this is the general procedure.
cbbryan
by rgraboske » Thu Dec 30, 2010 7:31 pm
Hpimichael02 wrote:only the bose versions have the out put, sadly most dont , chevy was behind the whole electronic movement... but from what i understand its only really meant for the dvd player package
I don't understand what the radio would have to do with the DVD player? The DVD player goes through the wireless headphones and the wired jack in the rear console.
When I ordered mine, I went with the non-Bose CD/Tape player radio and the DVD player.
Now that I think about it, I have a spare CD/Tape player radio in the garage somewhere. I'll have to go look later :coffee:
rgraboske
by fishsticks » Thu Dec 30, 2010 8:04 pm
My 6 disc Bose did not have an external input or output. I would have had to buy a separate module for it.
by Hpimichael02 » Fri Dec 31, 2010 2:19 pm
lol steve: i have to use all caps at work so its force of habbit swicthing between work things and here ...lol
that seems like allot of work id rather ditch the head unit since mine has no lights on the buttons anymore lol
but thanks for that info ima dismantle it this weekend
Hpimichael02
by SteveTB03 » Fri Dec 31, 2010 4:29 pm
Oh I dont care if you were yelling I was jjst picking on you :finger:
Go Big & Go Broke
SteveTB03
by The Roadie » Fri Dec 31, 2010 5:16 pm
I honestly can't figure what job uses a computer and forces you to use all caps. Emergency dispatch? What sort of equipment receives your messages? (If you can share....)
by fishsticks » Sat Jan 01, 2011 1:31 am
The Roadie wrote:I honestly can't figure what job uses a computer and forces you to use all caps. Emergency dispatch? What sort of equipment receives your messages? (If you can share....)
I did some work for a local truck salvage yard a while back. All of their computers had caps lock turned on. I had accessed a couple and instinctively turned it off. The employees there didn't know what to do when the letters didn't come up on the screen in caps.
Return to Electrical / Radios
