Anderson Power Winch Connectors...
by bartonmd » Mon Dec 20, 2010 12:17 pm
I searched and found a couple places they were mentioned, but if I couldn't dig the info out of the threads I'd posted in, I don't expect that most other mortals would be able to find it either...
Anybody find a better/cheaper place to buy the Anderson Power plugs for winch connections than here?
http://www.powerwerx.com/anderson-power ... 5-amp.html
$8/side, or $16 per set (+ $3.25 per dust cover)
Thanks,
by djthumper » Mon Dec 20, 2010 12:49 pm
I have stumbled across them at a couple of other sites but generally the same price or slightly higher. To the best of my knowledge with them Powerwerx is probably supplying most of the other places.
I use the powerpoles for my radios and several other electrical connections.
by Trail X » Mon Dec 20, 2010 1:04 pm
I bought mine from Expeditionexchange. Superwinch sells them as a package. Probably a tad overpriced, but I liked that it came with dust covers.
$35 for this:
by The Roadie » Mon Dec 20, 2010 3:56 pm
Greg bought a few pairs at a great price, IIRC. Forgot where, though.
by bartonmd » Mon Dec 20, 2010 3:59 pm
The Roadie wrote:Greg bought a few pairs at a great price, IIRC. Forgot where, though.
Ah, I went ahead and ordered (5) connectors from the Powerwerx place (along with the dust covers for the front, and the corrosion resistant boots for the wire side)...
(1) for the winch
(1) for the TB battery
(1) for the truck battery
(2) for an "extension cord" to run it on the rear of either vehicle...
Just out of curiousity, do you guys fuse that connection?
Thanks,
by Trail X » Mon Dec 20, 2010 4:02 pm
No fuse here.
by The Roadie » Mon Dec 20, 2010 4:23 pm
The connector is the fuse. Or the wire. :o
A large contactor relay, like the old starter relays, is one good way to make the wire harness and winch connection safe if you're running it to the back of the vehicle, for instance. I has some chafing on my positive wire between the battery and the bumper that scared the crap out of me when I found it.
by bartonmd » Mon Dec 20, 2010 4:47 pm
This is one that I found, but I don't know if I trust a circuit breaker that I pay $7 for...
http://compare.ebay.com/like/2804980403 ... 602_309572
by Trail X » Mon Dec 20, 2010 5:37 pm
400 just seems too high. I doubt your winch will pull over 250.
You could probably short your wire and not pull 400 amps.
by bartonmd » Mon Dec 20, 2010 5:43 pm
5.5HP * 742W/HP = 4081 Watts
4081W/12V = 340 Amps
The 5.5HP, I suspect, is a power output number... In thise case, if we consider the motor to be 85% effecient, we're talking about 4693 Watts, or 391 Amps at 12V...
I know the voltage isn't going to be 12V while pulling that much current, but it serves as good baseline...
by djthumper » Mon Dec 20, 2010 6:45 pm
They don't look much different than the ones on powerwerx for $30 and only capable of 150 amps.
by bartonmd » Mon Dec 20, 2010 7:29 pm
The winch showed up today... Manual says at full load is 425A for the 10, and 410A for the 8....
by fishsticks » Mon Dec 20, 2010 7:34 pm
My Harbor Fright 8K indicates 300A draw at max load. The motor is only rated at 4.1HP though.
by Trail X » Mon Dec 20, 2010 7:40 pm
Mike, what rating did you get? 10 or 12K?
What's the brand/make? Details details man!
by The Roadie » Mon Dec 20, 2010 8:52 pm
fishsticks wrote:My Harbor Fright 8K indicates 300A draw at max load. The motor is only rated at 4.1HP though.
Hehe. And a foot per fortnight line speed. :shoot:
by fishsticks » Mon Dec 20, 2010 9:27 pm
Quoted for truth. It's a REALLY good thing I'm a patient person. :)
by bartonmd » Mon Dec 20, 2010 9:30 pm
XRC-10
by bartonmd » Tue Dec 21, 2010 9:57 am
by bartonmd » Thu Dec 30, 2010 2:54 pm
These things are BEEFY! Had to use the 2ga setting for the 4ga ends... Not sure how I would have done this without the crimper at work...
Return to Electrical / Radios
